June 22, 2025, 02:53:08 AM *
Author Topic: nasco gear lever lock  (Read 4306 times)
mike
« on: February 24, 2003, 05:29:02 AM »
Hi I just got hold of a FE/FC nasco gear lever lock and was wondering if they were painted or left the aluminium finish originally, as mine now is just the alloy finish.
regards mike.
« Reply #1 on: February 25, 2003, 08:27:46 AM »
Painted,  some were black & others were in a hammer finish silver type of paint.
I think black is best - it looks better with the NASCO sticker.
« Reply #2 on: February 26, 2003, 03:13:47 AM »
That's interesting.  Every one I've ever seen (FE/FC or FB/EK) has been painted fire engine red in NSW.
I presume we're talking about the shifter sleeve and padlock, not the steering column 'collar' type lock.
gree
chopped greens
« Reply #3 on: February 26, 2003, 04:35:02 AM »
how do you get these things off the steering column by the way?
af riend has just bought an ek ute and it has the lock on the column, but can't see ho to actually remove it. a special tool of some kind? Huh Huh
simon
« Reply #4 on: February 26, 2003, 05:38:16 AM »
The collar type (see this page here) is designed in such a way that it can't be removed.  Otherwise what would be the point? Roll Eyes  It uses two shear screws that you presumably could drill out if you were very very careful.
If you've got the key for it consider swapping the whole column - it might be easier!
By the way, if I'd stepped off the curb on Elizabeth and Park Streets on my way back from lunch today (1.45-ish) I would have been under the green machine!  She's lookin' cool - although we're both better off for me not seeing the underside today Grin Grin
mike
« Reply #5 on: February 26, 2003, 07:03:34 AM »
Hi Gree & Ret yes it is the gear lever lock type not the tube and padlock type, Gree  to get it off all you do is drill into the shear off bolts carefully i used a 4.7mm drillbit and then knocked into the hole a 6 sided attachment (you know the ones you always get when you buy attachments for your cordless drill) and fit a socket onto this and undo, mine undid quite easy, then its just a matter of getting it re-keyed and either buying or making shear off bolts and refit.
regards mike.
gree
chopped greens
« Reply #6 on: February 26, 2003, 10:28:51 AM »
 Shocked
hey RET, a near miss eh?! i think i was chuffing along a bit too..  Grin
She's lookin' cool
just whacked on a coat of "nufinish" ha ha! the paint is getting very worn out, and it actually brought it up pretty well, its glossy again anyway!
thanks for the info about the lock guys, chuck (the friend of mine with the lock - hi chuck!). i am pretty sure that he wants to get rid of it, so maybe if anyone wants it he may swap. sorry for putting words in your mouth chuck, maybe you'd better speak for yourself here!
simon
Page created in 0.028 seconds with 20 queries.
