September 09, 2025, 03:57:57 AM *
Author Topic: wat dose SA reg require for a shortened diff?  (Read 3023 times)
smokey
« on: September 28, 2010, 09:45:02 PM »
Gday has anyone in sa put a shortened diff in a fc because i want run a little bit of rim offset eg. 8" rim 3"3/8 back space.
rang my engineer but he just didn't get it, saying why would you want to do that?
I asked him what he would like to see as far as, just billet axel's with h/duty bearings or a full floating axel kit, like on a drag car.
Can anyone give me an insite into expectations or know the legallities of this mod or give me someone to talk to.
Have tryed to contact someone at Transport SA about this, but im pretty sure they answer the phone, put you on hold, point, laugh, then go home or something.
                          Any help would be cool Grin
« Reply #1 on: September 28, 2010, 11:31:23 PM »
Chase up a guy called Craig Walkom (Walkom Automotive & Performance Engines), try the White Pages or call Directories. He works/worked for Regency, Top Bloke, builds tough cars and engines and should be able to point you in the right direction.
« Reply #2 on: September 29, 2010, 07:55:52 AM »
Hey Smokey,
not sure if this helps but in NSW
they say if the diff is narrowed, use the track width of the original- less the amount narrowed plus 25mm.
then they go on further to say "all rims fitted to"an axle" must be of the same diameter, offset, width and mounting configuration (except for spare wheels used in an emergency situation".
I would find an axle with the closest offset and size you wish to run, then shorten that diff.. you mentioned a VT ute earlier?  perhaps this is the best bet... some of the HSV's run pretty wild rims.
smokey
« Reply #3 on: September 30, 2010, 08:48:17 PM »
Thanks heaps guys
Will give Craig a ring and ask wat he recons. Spoke to rod from Rodtech who has built all my previous diffs for other projects & race cars
Ive had over the years. He seems to think that its what ever makes the engineer happy, so over engineered or heavier duty the better.
But that means more coin. So he may have an ulterior motive.$$$$
thanks again for all your help.
                                            "GO THE 308"
« Reply #4 on: October 01, 2010, 08:05:19 AM »
hey Smokey,
I know you've probably thought about this already but those big rims will need the wheel housings modified... mini tubs, tubs etc.
6 or 7 inch in a std wheel tub is a squeeze, 8 inch definitely tubbed.
Got pics of your project?
