April 09, 2025, 11:04:51 PM *
Author Topic: Mystery air vent on a '58 FC Station Wagon - Help!!  (Read 2756 times)
Mutley
« on: June 17, 2009, 06:01:31 PM »
Hi all
OK - dumb question alert....
I recently bought a '58 FC stn wagon.  There's a small lever underneath the glove box that opens a flap on the outside of the car right in front of the wiper blades.  When it's open, air blows in from underneath the dash and it seems to have 3 positions (low air to high air).
My question is how do you get the INSIDE air vents in front of the windscreen (?? de-misters) to work?  Should this lever do it or might it be broken?  Also, is there a heater you can add to the FC?
thanks everyone
« Reply #1 on: June 17, 2009, 06:49:28 PM »
The vent only allows air into the cabin in the manner you've described. Sometimes referred to as "turning on the air conditioning" Grin
The vents at the top of the dash aren't connected to anything. You had to purchase one of the accessory heater and demister packages to make these functional. The demister had hoses running up to these vents, which were attached to a device a bit like a miniature metal vacuum cleaner head, that fed the air up the vent.
I believe that FB/EK had a heater element accessory that fitted into the vent, but it doesn't fit the FE/FC. The plenum chamber is completely different and so is the vent itself.
Original heaters come up on Ebay and elsewhere from time to time. If you're not concerned about originality there are plenty of options out there, from small hot-rod air-cond/heater kits to anything you care to pull out of a different model car.
Hope that helps
Mutley
« Reply #2 on: June 17, 2009, 09:14:14 PM »
Hi RET
Thanks for your help.  I've seen heaters on ebay every now and then so I suppose I'll have a bid next time.
cheers!
Mutley
« Reply #3 on: June 17, 2009, 09:35:10 PM »
There is a heater in the Vic club upcoming auction
Page created in 0.052 seconds with 19 queries.
