August 21, 2025, 07:09:13 PM *
Author Topic: Bolt Pattern  (Read 3840 times)
spider
GO THE MIGHTY GREY MOTOR
« on: December 14, 2002, 01:07:25 AM »
Hi to all Cheesy,
                  I am wondering if anyone can tell me if the bolt pattern on the back of a grey motor is the same as a red motor, as in 186. Huh
Cheer's Spider Grin
FC-V8
Not enough hours in the day
« Reply #1 on: December 14, 2002, 01:29:28 AM »
Hi Spider
        They are the same bolt pattern,If my memory serves me correctly I bolting a 186 to the original gearbox years ago to my first FC.
Glenn
0401-065-201
« Reply #2 on: December 14, 2002, 08:15:53 AM »
Spider is spot on, the Poo Mobile has Red 149 with original grey 'box - all bolts up no problems. Just don't go giving that big bore 186 too much throttle too quick or you'll have a big mess to clean up  Cry
brads59
OLD OLDENS=STYLE
« Reply #3 on: December 14, 2002, 09:58:16 AM »
Hi guys,
Maybe try an all syncro box out of a HQ?
Still a three on the tree,but much more user friendly....
Cheers BRAD............
1959 Black Std sedan
spider
« Reply #4 on: December 14, 2002, 11:17:40 AM »
;DThank's everyone,
                                 The reason i asked is i wanted to run a 5 speed toyota box behind the grey motor, and wasn't sure that when i ordered the adaptor kit, if i had to buy a adaptor kit just for a grey but since it is the same as a red motor as in bolt pattern theres no problem Smiley i will know what to order. Since the grey motor is going to be bombed to the eyeballs and be totally a mongrel to drive on the road [MAGNIFICENT Grin]  I wanted a good manual box behind it plus the bonus of a overdrive.
Cheers Spider
« Reply #5 on: December 14, 2002, 11:17:51 AM »
Brad,
Fitment of later model synchro gearbox's need floor and gearbox crossmember mods - and engineers reports. Better result, and able to safely pull chirpies into second  Grin just more stuffing around.........
FE_STD_WAGON
« Reply #6 on: December 14, 2002, 01:10:23 PM »
Hi spider
Just a point to remember if you get bellhousing to suit a celica 5 speed to a red motor [which is the same bolt pattern as a grey] it wont have the mounting bolt holes for the rear engine mounts to suit the grey. So I guess I'm saying you'll have to get a bellhousing to suit a grey.
Regards FE STD WAGON
spider
« Reply #7 on: December 14, 2002, 10:15:32 PM »
Thanks FE STD WAGON Wink
                                        Now there is a point i would of forgotten all about. Thank's Mate for reminding me of the different engine mount's. I am working on the missus fe that has a 186 and forget that the engine mounts on my grey are different Smiley
Cheers Spider
