August 04, 2025, 07:45:50 PM *
Author Topic: Vacuum tank  (Read 2981 times)
crossply
Paul Reyntjes
« on: June 01, 2008, 09:22:58 PM »
i got this tank with my wagon. it was bolted to the right side inner mudguard but not hooked up. I can only assume that it is a reservoir for vacuum wipers. I haven't seen one before. Does anyone know anything about these?
Paul
sexyfc
John greco
« Reply #1 on: June 01, 2008, 09:33:55 PM »
Hi Paul,engines with large cams have very little vacum at idle, so the brake pedle would be hard, vacuum tank will store the vacuum for your brakes when needed. (Something around those lines)
cheers john
Project started 16/01/08.
MalFE
« Reply #2 on: June 03, 2008, 11:27:20 AM »
Hi Paul.
I have a Repco PBR trailer brake kit which uses a vacuum tank the same as yours.
I used it on a HK that I had for towing my vacuum braked caravan in the 70s.
Cheers.
Mal
crossply
Paul Reyntjes
« Reply #3 on: June 03, 2008, 02:07:30 PM »
Thanks for the info guys,
I wasn't sure about the tank as it has no brand name or identification markings on it. The car did have a tow bar on it but no sign of vacuum assisted brakes any more. I'd be interested to see how it is supposed to be hooked up.
Paul
« Reply #4 on: June 03, 2008, 02:29:53 PM »
The Hook up is very easy,this tank goes inline in the vacuum hose that normally runs from the intake manifold to the booster.......FC427......
« Reply #5 on: June 03, 2008, 05:40:41 PM »
There should be separate in and an out ports since it should have valving to prevent air entering the tank once the engine has stopped.  If it doesn't then valves need to be incorporated in the lines
