September 07, 2025, 07:05:48 PM *
Author Topic: Supra 5 Spd  (Read 4885 times)
fcfromscratch
FC - Fantastic Cars
« on: August 05, 2007, 09:51:09 PM »
Hi All,
I have a query about the various bellhousings available for fitting of Supra 5 spd to holden red 6.  I have a possibility of a 202/Supra box acquisition for implant in my FC Special Sdn.  The bellhousing has "commodore-supra" imprinted on top.  However, the clutch is cable operated (for the Commodore?), cable included.  I need to know, is this bellhousing adaptable to my need for a hydraulic clutch slave cylinder with off-the-shelf parts and brackets.....or do I need another more suitable bellhousing adaption for a simple, bolt-on trouble free installation?
cheers...Brad
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #1 on: August 05, 2007, 10:06:19 PM »
Brad,
check with Dellow Automotive  http://www.dellowauto.com.au  they produce all parts and kits for allmost any conversions.
regards
Weddo
fcfromscratch
FC - Fantastic Cars
« Reply #2 on: August 06, 2007, 10:16:10 PM »
Thanks Weddo,
Have looked at the Dellows catalogue and have seen that they "seem" to have a different casting for the cable and hydraulic clutch versions of the conversion to red Holden six...(is this correct, does anyone know for sure?)
I also looked at CRS catalogue and saw that their casting has two mounting points inside the bellhousing for pivots either side of the input shaft, with an extra kit required for the cable implementation.
I guess my problem is (at this point) that I don't know whether its a Dellow or CRS bellhousing on the one I have a chance of getting hold of.  All I know is that it has COMMODORE-SUPRA stamped into the top of the bellhousing casting and has a cable clutch setup pivot and fork.
cheers.....Brad
fe1957
Turbo Charged
« Reply #3 on: August 06, 2007, 10:33:17 PM »
This is testing my memory a bit however I think you can purchase a cast bracket that bolts to bellhousing to mount a slave cylinder instead of using the cable.
Sorry I can't be 100%
Grant
OFE570
« Reply #4 on: August 07, 2007, 08:16:54 AM »
i have put a couple of 5 speeds (celica steel case) on reds and they always used the hydraulic slave (from a grey motor).
on one particular application,we put a CRS cast bracket onto a Dellow housing and it fit with minor grinding.
again I cant tell you for sure, you would need to speak with Dellows for the safest answer.
fastjbav6
OK start her up !
« Reply #5 on: August 07, 2007, 07:06:01 PM »
Hey Brad,
When I ordered my bell housing for my V6 Chev to 5 speed Supra conversion for my kit car, I was asked if I was going to use a cable or hydraulic set up and also if the clutch fork was on the left or right side. CRS is cast in the bell housing, I don't know about Dellow.
As far as I know my  CRS housing is stronger than other competitor housings due to extra ribs in the housing. Don't know if this applies to all housings.
Spoke to a mate that tried to convert from cable to hydraulic a few years ago using same housing. It didn't work too well because there wasn't a machined flat surface to mount the slave cylinder and he cut the casing that the cable went through. Result was one wasted housing. He doesn't recall the brand.
Seb
Yellow Knight
jfk
« Reply #6 on: August 08, 2007, 05:08:33 PM »
Ask Geoff Dellow. I recently picked his brains about a 5 Speed steel case I bolted to the V6 in my FC and he just loves to chat. He is an old Street Rodder from years back....one of the fathers of our sport. There are about 4 different types of boxes and with a little information he can identifiy it for you, talk clutches etc etc. Tell him "The President" said hi...JFK
JFK
fcfromscratch
FC - Fantastic Cars
« Reply #7 on: August 08, 2007, 10:56:37 PM »
Thanks all for your input....I'll get hold of the gearbox (I hope) and have a closer look at it to see which brand/type it actually is.  Then I can ask the needed questions of the folks you've mentioned to see if I can get the necessary bits for the hydraulic clutch.
cheers....Brad
