Throttle shaft BXOV-1
Started by Wasim, November 20, 2017, 09:53:31 AM
Wasim
Hello,
        Is the throttle shaft in a stromberg BXUV-2 interchangeable with a BXOV-1?
Reasoning being the throttle shaft and lever are one piece on a BXOV-1 whereas the BXUV-2 is a two piece set up making it easy to add a ‘w’ clamp for multiple carburettor set up.
Thanks, Wasim
South Australia
Throttle bore is the same... so must come close. Depends on bearing hole size (on the roar, and haven't got one here to check).
Wasim,
Yes.  The BXUV-2 throttle shaft is a drop-in replacement for the BXOV-1 shaft.  The only difference is the thread and nut at the throttle lever end.
