FE sedan
Started by FCRB26, July 28, 2010, 04:20:55 PM
Well i changed the arm on the throttle body .
Drilled and tapped fitted grub screws.
Made and fitted balancing screws.
Now onto the idler arm.
Some dick ordered 8 left hand m5 heimes so waiting on new ones to show up.
Home made injector rail just needs mounts and pressure regulator fitted.
Injector bosses next to be fitted in the morning.
Home made heim template because im missing 3 to jig up with.
So what are you getting for Christmas then!!??
Quote from: NES304 on December 24, 2015, 03:28:27 PM
Hopefully a fc wagon  :D
FATBOY
lol my missus would happily sell you my fe wagon the mood that she is in
looking good pete
regards fat
fatboy
0414712441
I have my eye on 1 complete..
Snuck out the shed and finished fuel rail and mounts also finished injector ports into the manifold.
Everything seems to clear the injector wiring will clear.
The tps sensor will clear.
Will have to relocate throttle arm return spring is the only set back.
That's just beautiful - so neat and clean
Thanks Ken.
Let's hope it runs  ;D
This mornings job done.
Just needs a acid bath then some etch primer then satin black.
Your insane Pete do you ever sleep buddy I love that you have these ideas in your head and then turn them into reality
Neil H
Quote from: FireKraka on December 27, 2015, 08:16:43 PM
Neil H
Thanks Neil no time for sleep cars to build. :D
DN2168
"You're an ideas man"
Getting closer
The wife went away so went to work late and cut pressure reg bkt
Finished fuel rail
Finished tank ready to wire
Making fuel line clamps very tedious
Also found a roof rack which i will powdercoat.
Was cheering to find one..
Got one of the first batches of yella terra roller rockers few glitches but all fitted now.
New roof basket all powder coated needs longer legs so will make them next week.
Rims are powder coated  going tubeless found some 20mm valve stems.
Manifold is finally finished vaccum ports fitted
My little helper was out in the shed with me ..
Jeez Pete, I wish I had half your talent!! the whole setup looks fantastic. The roller rockers look like they were always there, can't wait to see the finished product. What is the capacity of the fuel tank?the FE is looking almost as cool as the FC. All you have to do now i find a couple more FE's and you will have a full set of both.
Regards, Jim
Just had a look on Yellaterra's site, they have a few photo's of the roller rocker setup. They have two shots of your engine, looks good.
Amazing .............
camxsmith
Pete I have to say I have loved following you posts. Your skills are truly grand and the out put looks amazing. So please  keep the posts coming. Great work. ;)
