Steer rack shorten
Started by NES304, March 27, 2012, 07:01:10 AM
I have a bloke who can shorten a steering rack so I can rear mount on my HR front end. Thought I'd get some other opinions so I rang around. I've had a few steering mobs tell me just to shorten the ends instead of cutting the centre part. Wouldn't I run into some issues if the ends don't pivot in similar angle to the lower wishbone?
If I am running the VT discs then how much over all does it need to be shortened?
Thanks in advance.......
of course it will bump steer draw your self a picture  with a compass and think about it hence why you will get the bump steer.
Discs dont matter at all the rack mounts to the steering arm not the discs ;D
Stupid bump steer, Don't want that. It is just as I thought. Wonder why I was told by a steering mob just to shorten the ends?
Centreline of ack pivots need to be the same distance apart as the centreline of the lower wishbone bolts
Just get that rack from work and take it to stewy
Roger
I'll have to tee up a time
Stewy
Quote from: fchoon on March 27, 2012, 06:13:38 PM
If it was timber I could do it for sure (being a chippy)  ;)
Cheers Stewy   8)
Just watch for potholes if its timber you might break a steering arm.. ;D
Quote from: fchoon on March 28, 2012, 05:11:58 AM
Just weld them up again with WOODCRAFT electrodes  ;D ;D ;D ;D ;D ;D
Liquid nails also works.. ;D
simins
oh my god I just scored an LSD VS ute diff and now need that shortened.......
Liquid nails here too?
Stewy
Its cheaper by the box   ;)
