Here we go again!!!
Started by FCV08, December 22, 2009, 11:45:21 PM
FCV08
The rails are profile cut to the shape of the underside of the floor. I stitch welded them on utilising a 4 inch weld. They are also butt welded to the front underfloor crossmember and welded and plated at the rear front spring hanger. At the rear they are also capped to seal the top of the rails. Although you cannot see it the kframes are also plated with 3mm plate for strengthening the front end as part of the mod.
Craig
FCV08
Got the number plates today.
Can't wait to see them driving along the road.
Craig D
Craig they look great.
The car is not far now. The updates are a treat.
Wayne b
FCV08
It has been a little while since the last update.
I have since fitted a under dash heater assy, radiator, battery cable, and new alloy fuel tank.
I am avoiding the inevitable wiring like the plague. I will eventually ruin out of other things.
Here are some shots of my work so far.
Modified the radiator support brace.
Along with the grill support panel
Also recessed the front subframe and made up lower radiator support mounts whicxh have the original VN commodore rubber mounts
Boot floor removed and modified floor bracing and sheeting fitted waiting for new tank
Part 1
FCV08
Part 2 (too many photos to run all at once  ??? ???)
and here is the new tank all fitted. Thanks goes to a great freind who build this off a set of hand drawn plans. Not bad !!
The two slots at the rear are for white LED lights strips as reversing lights
Enough room to run the exhaust down both sides
Capacity works out around 70 litres or roughly 15 1/2 gallons. May need and extra couple of leaves in the rear ;D ;D
You will see the rear sway bar hanging underneath as well. I am currently chasing a modified sway bar and need to measure and send this one off to get one made.
So there it is for now. I will add some shots of the heater core as well in the next post.
Oh yes and that wiring  >:( >:(
Regards  Craig D
FE 4 ME
Hi there,
   great build you got going on.... the craftmanship in your welding and fabrication is inspiring to say the least
2 questions please
1. What MIG welder are you using ( looked kinda like a 130 amp in the pic ) ?.... i think i need a MIG welder soon
2. Is that a B&M Megashifter you installed ? if so can you post more pics of that install please ??
keep up the great work... i'm sure we all are looking forward to your next posts
"Have A Great Holden ( FE ) Day !!!"  :):):)
FE 4 ME
FCV08
FE4ME
Welder is a WIA 175. My neighbours actually. Good bloke.
Craig D
FCV08
Not a B&M Shifter but the parts are interchangeable.
I built mounts onto the tunnel so that it added a bit more strength to the setup.
Will take some more photos at the weekend.
Craig D
FCV08
Just and update to let everyone know the car is back from the paint shop.
Now to put it all back together.
Will post some photos shortly.
Craig D
FCV08
It has been a little while so here is the update
It has fitted
I ceramic coated the extractors to minimise heat around the starter motor area and engine bay
Battery Box and new fuel tank installed
Running the Starter cable from the boot
Fuel and brakeline plumbing. That was fun  ??? ???
Fuel Pump Mounting
Through to the engine bay.
Shortened VN Diff and Custom Sway bar. Fulcrum Suspensions in Brissie were very helpful with making up the sway bar. Price was very reasonable.
Bit more colour.
Still toiling away and now thinking of the wiring tasks.
Hope you enjoy the update.
Craig D
So envious mate,
It looks fantastic!!! I know how it sounds too!!! Bet you cant wait to fire it up.
Some nice progress.
Good to see you made it all fit.
jack_fc
It just gets better and better...  :)
Looks great Craig; you must be getting excited at the prospect of getting it on the road by now...
Be interesting to see what you do with the interior (it will need to be bloody good to match the rest of the car!)
cheers, jack
FCV08
Thanks Jack
Interior is done and in the shed.
Will post some photos.
Craig D
Good stuff Craig. That custom sway bar looks the part.
Wayne b
FCV08
Here are some photos of the interior.
Seats - Embroidery, although not original, is a due to a touch of inspiration from Jack's efforts in white. Thanks Jack. I showed your photos to the upholsterer and he was certainly impressed.
Door trims back to a near original pattern
Visor completed
Panic straps, arm rests and visors
Well now its down to putting it all back together.
Craig D
2brite
jack_fc
Very impressive, Craig!  8) 8)
(but you knew I'd say that... ;))
BTW, rather than thanking me, thank Kathi - there was a hell of a lot of her influence shown in my interior...  :)
cheers, jack
DN2168
Looking really good craig, how much more have you got to go?
Dean.
FCV08
Dean
Thanks for the knid words.
Still have all the wiring then put all the panels & doors back then interior.
Craig D
