July 19, 2025, 02:24:49 AM *
Author Topic: Engine loosing power  (Read 2425 times)
graham_fuller
« on: February 16, 2004, 06:33:24 AM »
Just replace the Carbi with a fully rebuilt unit.When I got the car Hot and put it under load the engine started to loose power.It is very hot at present that is air temperature.Dosent appear to be using water.could this be cuased by incorrect fuel mixture setting or am I looking more at head gasket trouble?
Graham Huh
« Reply #1 on: February 16, 2004, 09:48:00 AM »
Hi Graham,
It could be a number of things. Wink
Have you checked all the basics?
Plugs,points,timing etc.
A compression test or cylinder leakge test will tell you if you have a cylinder head or head gasket problem.
Did the car have the problem before you put the rebuilt carby on?
Have you checked the rebuilt carbys float level and is it getting full throttle?
Regards ACE Cool
graham_fuller
« Reply #2 on: February 16, 2004, 10:50:46 AM »
Hi Ace,
The problem wasn't there before the new carbi.I have just done some more drive testing and found the same problem in the cool.I can fix it by pulling out the choke then everything is sweet.any suggestions?
Thanks,
« Reply #3 on: February 16, 2004, 11:06:58 AM »
Graham,
It's most likely the main jet size. Pull the one out of your old carby (you'll need a special tool or a set of long nose pliers and some patience) and note the size - it's probably a number in the low 50's. Check the one in the new carby, its probably smaller causing the engine to starve for fuel under load.
graham_fuller
« Reply #4 on: February 17, 2004, 03:00:19 AM »
Thanks,
Craig and Ace looks like a change of jet will fix the problem.The New Carbi certainly fixed the surging that it used to suffer.
Graham Wink
« Reply #5 on: February 17, 2004, 06:41:05 AM »
Graham,
I suggest you purchase or borrow a main jet removal tool as i have had to remove some that have been attacked with long nose pliers Wink
If your motor is standard it should have either a .050 main jet with a no 66 power by-pass jet or a .051 with a no 67 power by-pass jet.
I hope this helps Smiley
Regards ACE Cool
