July 17, 2025, 01:05:46 PM *
Author Topic: TRIPLE STOMBERG LINKAGES  (Read 2063 times)
Blown_FC
« on: September 12, 2003, 12:12:48 AM »
This may or may not interest a few of you, but I was in search for a set of new linkages for my triple stromberg CD150's.
I went to Holdens, Repco, Coventry's, Marlows, Supercheap Autos, the local car shop, Rare Spares and even the Redline Website....no one had ever seen them before. ( I should explain ), my old linkages are the type that joins between the butterfly (throttle) spindles of each carb, simply just a rod about 12cm long, with an 'S' shaped bracket on each end with a round hole on one side of the bracket for the rod to go in, and an oval type shape of the spindle on the other side.
They are a very simple and effective setup, but no-one had ever seen them before.....until I rang a carby service shop in my old home town ( Mandurah WA ), and the guy said...yep, no worries, I know exactly what you are looking for, $30, Done !
So if anyone else out there is looking for NEW linkages and are having the problems I had, let me know and I'll fix you up !
Mark
P.S.    And Yes, they came in a REDLINE package....Huh
Fast_Eddie
« Reply #1 on: September 12, 2003, 10:22:37 AM »
Any chance of posting a photo of the set up?
I have a dual set up with no linkages, and I always considered the link between the butterfly pivots to be the neatest solution.
Edward
Blown_FC
« Reply #2 on: September 12, 2003, 10:05:22 PM »
Ed.....The photos are too big to post on forum....email me and I'll reply with attachments for you to open.
The photos are of the complete triple carb set up when I bought them, so they are a bit grubby and a bit hard to see, but I can email you a diagram that I drew up on my computer. showing what they look like.
The carb linkage kit that I talked about in this message thread, does in fact suit the TWIN downdraft strombergs.  The triples have a slightly larger spindle and of course, shorter rods between the carbs....but that was not a problem, I just carefully filed the holes bigger on the bracket ends to fit onto the spindles properly, and just cut a small length off the rod to fit the triple spacing as opposed to the twin spacing which is further apart.
But for twin strommies.....they fit perfectly....
Anyway, just email me ( markh@mccays.com.au ), and let me know, so I can email them to you instead of posting on the forum.  )
Mark
