July 14, 2025, 03:02:02 PM *
Author Topic: Winder washers  (Read 6048 times)
« on: May 16, 2015, 08:55:36 PM »
Can someone please tell me the purpose of these foam rubber washers (no. 26) Huh
I'm guessing they fit to the winder regulator.
« Reply #1 on: May 16, 2015, 09:03:39 PM »
I would have thought to stop dust ingress into the cab.
« Reply #2 on: May 16, 2015, 09:09:54 PM »
I read that from someone selling them but there are none on the door handles.
« Reply #3 on: May 16, 2015, 09:18:53 PM »
They fit on the regulator and go behind the door trim.
« Reply #4 on: May 16, 2015, 09:20:29 PM »
maybe because the winder goes into the door cavity where as the door opener doesnt its only a rod going back to the door mechanism ?
« Reply #5 on: May 16, 2015, 09:23:14 PM »
Sounds right. Thanks Pete & Ken.
« Reply #6 on: May 18, 2015, 11:32:50 AM »
Would anyone happen to have the diameter & thickness for these?
The car is a few hours away & to buy the kit with post is >$20.
GMHwagoon
« Reply #7 on: May 18, 2015, 03:42:08 PM »
dave
     do you want me to post you up some l some second hand ones if your interested
      greg
« Reply #8 on: May 18, 2015, 03:53:46 PM »
Thanks Greg. Thought I'd just cut some left over foam rubber used in concrete joints.
Assuming it's similar material, what do they measure in thickness & diameter?
« Reply #9 on: May 19, 2015, 07:14:20 AM »
Dave, the felt washer fits around the winder post on the regulator and is forced onto the inside of the door frame when the regulator is screwed into position. The spring goes between the door and the trim and the metal washer goes between the handle and the trim. As the others have said, the felt pad would be to stop dust and rattles.
« Reply #10 on: May 19, 2015, 10:59:20 AM »
I have foam sticky backed tape if you want me to cut them on the waterjet ?
« Reply #11 on: May 19, 2015, 01:36:00 PM »
Thanks all for the detail & offers. Sorted now.
Page created in 0.046 seconds with 19 queries.
