July 18, 2025, 02:05:25 PM *
Author Topic: Wtb gemini booster  (Read 9210 times)
ekdave
www.offyarocker promotions.com
« on: July 22, 2013, 06:59:45 PM »
Anyone got a spare gemini booster from a conversion
They are not going ahead with ?
Cheers Dave
***just cruise***
                    FB-EK HOLDEN CAR CLUB
           OF SOUTH AUSTRALIA INCORPORATED
http://adelaideearlyholdens.forumsplace.com/index.html
« Reply #1 on: July 22, 2013, 07:21:19 PM »
There about as hard as 200B ones to find at the moment... Good luck ill ask bloke up the road with geminis.
« Reply #2 on: July 22, 2013, 07:57:52 PM »
http://www.gumtree.com.au/s-ad/thomastown/wrecking/wrecking-td-tg-gemini/1023876894
« Reply #3 on: July 22, 2013, 07:59:48 PM »
bonnet in good condition $80
guards in good condition abit of surface rust but nothing bad $70 each
doors all rust free $80 each
headlights x3 in good condition $100 a pair
taillights x2 in good condition $100 a pair
centre console auto $30
gemini hand brake setup cable and handbrake and brackets $70
td tg bars x2 in good condition $120 a pair
petrol tank in good condition $60
gemini windows back and front in good condition $80 each
gemini seats out of slx with matching door trims in green/blue $300
booster in mint condition with xb master $150
side mirrors that control them from your door trim x3 $100 for all three.
few more parts i have
0478153495
« Reply #4 on: July 22, 2013, 08:13:53 PM »
This may suit your application, Im assuming you wanna run a falcon booster?
http://www.ebay.com.au/itm/BRAKE-BOOSTER-UNIVERSAIL-7-SINGLE-DIAPHRAM-PLAIN-/181117971796
fink
« Reply #5 on: July 22, 2013, 08:18:04 PM »
Was there today.my old stomp'n ground! Tongue
« Reply #6 on: July 22, 2013, 08:22:13 PM »
These are sexy as finky me boy  Cheesy Kiss Kiss
http://www.ebay.com.au/itm/WILWOOD-POLISHED-TANDEM-MASTER-CYLINDER-1-BORE-INTEGRATED-RESERVOIR-WIL2608555P-/180857221018
« Reply #7 on: July 22, 2013, 08:31:46 PM »
Thats what my sedan has. $220 from summit
The cheap arse booster fits the wilwood cylinder
Crumpsnr
Shellharbour NSW
« Reply #8 on: July 22, 2013, 08:52:27 PM »
What cheap arse booster would that be Pete?  Ta, Martyn
« Reply #9 on: July 22, 2013, 08:59:42 PM »
The one at Pete's shop  Cheesy Cheesy Cheesy
« Reply #10 on: July 23, 2013, 05:39:22 AM »
The ebay one at the top of the page bolted up to the wilwood one
« Reply #11 on: July 23, 2013, 09:11:55 AM »
On the subject of boosters...
how can you tell a double diaphragm booster from a single..  physical size?
I'm leaning toward using an OEM booster versus a cheap ebay one, as I read the ebay ones are not rebuildable..  is there truth to this?
Pete I think Datsport sells the 200B boosters. I've got a 1200 booster at home and they are tiny little things, I think they are similar to the 200B. Would that provide enough boost?
« Reply #12 on: July 23, 2013, 10:29:55 AM »
A 200 is a fair bit bigger than a 1000 and a 180B is different again and i was running a 200B on the sedan and wasnt overlly happy with it im going to check it right out before i use it as the ute has a bit more poke than the sedan use too.
« Reply #13 on: July 23, 2013, 12:22:36 PM »
Think from memory the Gemini booster has about 860 lbs of force only good for a light weight car ......FC427.......
ekdave
« Reply #14 on: July 23, 2013, 06:43:44 PM »
Thanks guys
Was going to run the gemini booster and commodore
Master
4 wheel commodore discs
Thought the gemini booster was the norm for this set up ?
Cheers Dave
***just cruise***
Crumpsnr
Shellharbour NSW
« Reply #15 on: July 23, 2013, 06:47:07 PM »
Thanks Pete  Smiley
Page created in 0.036 seconds with 16 queries.
