July 15, 2025, 03:20:55 AM *
Pages: [1] 2   Go Down
Author Topic: FC253 Wagon  (Read 16502 times)
Gordon
« on: March 13, 2013, 01:04:00 PM »
I thought its time to start a post of my wagon under construction ( or distruction) plan is 253 auto,commo diff, rear mounted steering, column shift ,bench seat. Have gathered most parts need front stub axles to fit hr front end with vr commo brakes and other things along the way drive shaft etc, This will be a slow project due to time and money but most seem to be that way
Gordon
« Last Edit: April 26, 2015, 12:44:46 PM by RET » Logged
« Reply #1 on: March 14, 2013, 01:14:38 PM »
Hi Gordon
Looks like you have a good car to start the build with.
I think the point is to just stick with it, things do take time if you are on a budget you sound like me I have had my FC for 16 years and it feels that most of that time I have been trying to finish it.
Don't be afraid to ask advice either the guys on here are really helpful.
Good luck and keep the pictures coming.
Neil
Gordon
« Reply #2 on: May 04, 2013, 09:14:32 PM »
Hi a bit of an update on my wagon, but first a few photos of the first wagon i bought with the intention of rebuilding but to much work so stripped for parts
You will notice the small hole in the roof as it was used as a pig shooter, and the spare replacement roof
And the update on my wagon almost ready to be stripped,blasted
Commodore diff ready to be shortened
Subframe and HR frontend ready to be blasted
Finally the motor im using
Thats it for now Gordon
« Last Edit: May 04, 2013, 09:22:02 PM by FC253 » Logged
« Reply #3 on: May 04, 2013, 09:43:39 PM »
253?
FCV08
FE FC Club of QLD
« Reply #4 on: May 04, 2013, 10:00:01 PM »
Gordon
Thanks for the update.
Keep the photos coming
Craig D
Gordon
« Reply #5 on: May 04, 2013, 10:07:56 PM »
Yeah 253 out of HJ ute Just looking for that "OLD SCHOOL" look, V8 Carby big crome airfilter but Pete suggested VN commodore V8 injection on it, so im looking in to that also
Gordon
FCV08
FE FC Club of QLD
« Reply #6 on: May 04, 2013, 10:09:19 PM »
Go injection hey NES Grin Grin Grin
« Reply #7 on: May 05, 2013, 09:00:23 AM »
FOR SURE!!!! Wink
Won't be stuffing around with valve stem seals or leaded additives plus a SH!T load more power, especially after I get into the computer and change it Grin
brett_f
« Reply #8 on: May 05, 2013, 02:11:42 PM »
Gordon,
Looks a pretty clean car to start with. As the previous boys said, cant beat injection. Turn key, starts and idles. No constant issues with tuning and in my opinion, looks cleaner under the bonnet. However, as you will see in previous posts wiring can sometimes be a headache. As all the boys know i had issues with engineers. Have you spoken to one yet. If so good but if not you need to. If you dont get the answer you want try another couple as they are all on different pages.
Keep up the good work. brett
Gordon
« Reply #9 on: May 05, 2013, 08:58:53 PM »
Hi thanks all ,was speaking to a engineer but he is no longer getting involved in cars because of all the law changes, so im looking for another if anyone knows of a good one in the sydney area please pm me
Will have a look into fuel injection
Gordon
« Reply #10 on: May 05, 2013, 11:18:00 PM »
Gordon, try Peter L Smith at Camden last I heard he was still going. I've sent you a message as well.
Reagrds Jim
« Reply #11 on: May 06, 2013, 11:37:53 AM »
G'day Gordon welcome to the forum, good to see another wagon getting rebuilt, looks like the old girl is in pretty good nick for her age.
           Pedro
Gordon
« Reply #12 on: May 07, 2013, 11:11:45 AM »
Thanks Pedro I've read and reread you build and cant wait to see it finished,what colours are you painting it, I am still undecided on colour
Gordon
« Reply #13 on: May 07, 2013, 11:20:49 AM »
Gordon,
Years ago I started a build using a 253 with exactly the same intentions as you.
I ended up with injected 308 because the injected heads off a VN with the large valves are too big for the 253.  It would work, but probably  not as well as some modified 253 heads.
then again you could stroke the 253 to 310.
Im an injection convert.. the time spent setting it up pays dividends later... I'm actually researching a megasquirt setup for my current project.. although I will make it look like a factory ECU for rego reasons.
« Reply #14 on: May 07, 2013, 12:15:40 PM »
As previously mentioned there are plenty of people willing to give you ideas ,so I thought I might also .Carefull consideration should be given to the axle length in mind of rim offset calliper clearance and stud pattern of axles.Also ride height can be set up as the diff housing is saddled for the early springs rather than using lowering blocks or resetting springs....mind you a recoed set of springs is the least of your expenses.I rebuilt a 2 tone green wagon very similar to the photo in 1999 with 192 and 4 speed so these photos bring back great memories.Just thinking about rear seatbelts in a wagon.I had horizontally mounted retractables on the rear wheel arches with stirrups on the back door pillars and my blue tag guy told me he could not pass them because of the lack of room for a back up plate.So if you go down this path and reinforce the mounting with a piece of steal inside the pillar get photos[proof] .Always a good idea to get a tag guy onside at the start of the project and ask first.good luck.
« Reply #15 on: May 07, 2013, 02:06:05 PM »
Hi HSV001 im doing the diff the same as this
http://fefcholden.org.au/forum/index.php/topic,22469.40.html
« Reply #16 on: May 07, 2013, 02:36:54 PM »
No worries Gordon, she's going to be sting red with black in the flash/insert, i had the same problem deciding on colours it took me ages and heaps of photoshopping by other members and mates to decide, i've still got all the pics so if you have any combinations you would like to see let me know and if i've got it i'll post it on here for you, i'll stick a pic up on my post of my paint scheme, i thought i had one on there but i can't find it, as far as your build goes the 253 would be a lot simpler because of no computers and no pollution gear but you can't beat the reliability and power of a modern engine, if i had my choice again i would go with a modern v6 or v8(more likely the eight) they fit so much easier than the rb30.
   Pedro
Gordon
« Reply #17 on: November 01, 2013, 01:55:06 PM »
A bit of an update, progress is slow, managed to build myself a rotisserie makes the rust repair so much easier.Very little rust in back end,need to replace cowl vent panel, two front floors and trans tunnel, pickup two outer sills from rare spares tomorrow $225 ea i was told and a bit of rust in the firewall recess where the top of subframe bolts on
That will keep me busy for now
Gordon
wutevr
« Reply #18 on: November 02, 2013, 12:00:34 PM »
looking good there Gordon im in Campbelltown too building a sedan
« Reply #19 on: December 04, 2014, 06:30:33 PM »
How's it going
Pages: [1] 2   Go Up
Page created in 0.046 seconds with 19 queries.
