Back again
Got the dodgy rusty pin fixed (back in 2013... not this morning)
But now the pedal isn't working correctly again
Heres some pics of the set up
the back of the pedal.
now it seems this part (arrowed) must be worn ? It moves and twists when you touch the pedal
ALSO... how is the actual pedal connected to the U shaped piece ? (the one that goes from here and across to where the new bolt screws through it) as it seems to be loose/worn at this point also
The rest of the setup. It's a mix of some original(?) linkage and new cable bits
where it comes through the floorboards
up the firewall
and pivots
and then ...
it converts to a cable
which runs around the firewall to the carby.
it was done about 12 years ago (when a lot of dodgy work was done by a supposedly reputable modifier )
it has never worked 100% right (theres a spot when trying to accelerate very slowly where it jumps and accelerates quickly)
I think the geometry and angles of pivoting are probably wrong (but I know nothing about geometry and pivoting things
Just lately I have noticed that the pedal doesn't sit as upright as it normally does
it moves to the left as you push it down (putting the toe of my big right foot behind the brake pedal)
and goes to the floor without getting proper acceleration
A where it usually sits
B where it currently sits
C pushed down it pivots off to the left
Is this a repairable problem or replace worn out parts ?
What parts are available (new ? secondhand?)
Or do I throw it all in the rubbish bin and start from scratch. I would like to keep the look of the original pedal on the floor (rather than do the commodore pedal conversion)
Help
