July 13, 2025, 07:12:34 PM *
Pages: 1 ... 16 17 [18] 19 20 ... 41   Go Down
Author Topic: Heart Transplant - adding 172ci  (Read 487709 times)
« Reply #340 on: August 16, 2013, 08:04:29 AM »
I know why he has a woody going by the websites he sent me yesty.. Cheesy
« Reply #341 on: August 16, 2013, 12:57:22 PM »
« Reply #342 on: August 16, 2013, 06:13:31 PM »
Thats awkward I thought we were texting the Lionel Ritchie Beer commercial?
http://www.smh.com.au/entertainment/lionel-richies-cash-splash-in-beer-commercial-20130627-2oyvo.html
Hey where's the "Mallaby" Trademark. Someone might steal it.
« Reply #343 on: August 17, 2013, 08:49:29 AM »
Tip.... New Tap King holds ten beers and if administered in one sitting you get a FREE hangover.
« Reply #344 on: August 17, 2013, 09:17:17 AM »
Nes I've seen them in the shops. How are they?
Regards Wayne b
« Reply #345 on: August 17, 2013, 09:29:20 AM »
Bit gymicky but still good I think. Cheaper to buy a carton but I like a cold beer glass. It pushes the last drop out too so no wastage (except down my chin onto my shirt!)
« Reply #346 on: August 17, 2013, 02:57:21 PM »
I know I keep chopping and changing (pun intended ) but I'm back on the diff. Had to have axles re straightened and shortened as the dickhead that did it pretty much failed. The guy is Promac at Cardiff and has shut down. If I every catch him ill re arrange his nose. It has angered me to no end and cost me a lot to fix. He even set the axles up for drum brakes and its clearly a disc brake end.
Here is how much I had to trim
New bearings for discs on.
This is apparently out of an 81 Bronco
With a drum brake bearing this bit in here 'walked' out 2.4mm
These are the rotors I'm using and noticed the slots are directional
« Reply #347 on: August 17, 2013, 04:09:22 PM »
Hope they on the right way!
« Reply #348 on: August 17, 2013, 07:10:31 PM »
Here's my how to double flare guide
First make sure you get a nice square cut on the end with a pipe cutter
Slide through the clamp so that the pipe hangs out the same length as the base of the flare bit
Put the flare bit in
Twist to drive the flare bit down
Remove pipe to show flare. Just remember to put the nut on prior unlike my mistake!!! Angry
« Reply #349 on: August 17, 2013, 07:11:06 PM »
« Reply #350 on: August 17, 2013, 08:41:45 PM »
Very Good. That is all  Wink
« Reply #351 on: August 17, 2013, 09:04:55 PM »
 Shocked Tongue Smiley
« Reply #352 on: August 17, 2013, 10:22:49 PM »
Thanks for all the emoticons, if only I had some sort of clamp in my possession to do the lines along the body Huh
« Reply #353 on: August 18, 2013, 06:46:08 AM »
There sitting here home after 1.
So in the end your axles probablly werent too long he just used the wrong bearings? so the new bearings would have spaced them back out 3 to 4 mm.
« Reply #354 on: August 18, 2013, 08:25:08 AM »
No it's the black bit at the end that's skinnier and doesn't force the axle in.
FCV08
FE FC Club of QLD
« Reply #355 on: August 18, 2013, 04:46:27 PM »
Hey NES
To make it even better remove the burr from the inner side of the cut end and file the end square.
Looking good though, and yes don't forget the flare nut  Huh Huh Huh
Craig D
« Reply #356 on: August 18, 2013, 07:07:45 PM »
Smashing out the photos now... Did the brake lines for the diff
« Reply #357 on: August 18, 2013, 07:17:08 PM »
Thanks for the photos. I'm currently out of action. Got ct scan back for my back the other day. Turns out I have degenerative spinal disease, osteo and the bottom 4 disks are bulging. I only went in there thinking my hip was crook lol. It's not an injury. I was just carrying around the engine block the other day no probs.
« Reply #358 on: August 20, 2013, 12:43:16 PM »
No worries Deano. I screwed my back ten years ago L4 L5 discs and had seven months of crap physio. After I spent three weeks at a chiropractor I was running!
All new rubbers for the diff and the bloody hangers are too short thanks to a taller diff (standard Wink) saddle
« Reply #359 on: August 20, 2013, 01:23:37 PM »
Just wondering if those mounting brackets on the backing plates are going to scrape the inner guards or have you already ollowed for that. I didn't look all the way through the photos carefully but all the commodore rear ends I've put in I had to relocate those brackets so the hoses wouldn't shear off with suspension travel. Just think its worth a look. Cheers
Pages: 1 ... 16 17 [18] 19 20 ... 41   Go Up
Page created in 0.058 seconds with 17 queries.
