July 18, 2025, 08:12:51 AM *
Author Topic: Killing time  (Read 10539 times)
Gary C
« on: February 07, 2010, 09:51:50 PM »
Just killing some time waiting for my sedan (engine bay refurb) to return from the paintshop.The ute only needs a couple of things done, wont take long and definately not going to spend any money. Just gunna drive it and enjoy it.
Great to drive, just gotta sort out a couple of odd noises.
found a few things a bit suss,,not much,should be easy ,wont take long and it will be back on the road!
Sound familiar!
Gary C
fe-ambo
« Reply #1 on: February 08, 2010, 04:10:41 AM »
Those haunting words.... think we have all said them at some stage.
Hope it works out well for you.
Paul
If take a ride in a ambulance you gotta a chance,
if you take a ride in a hearse its gotta be worse.
Check out this website for more photos
http://gallery.oldholden.com/hr-hearse
« Reply #2 on: February 08, 2010, 10:49:46 AM »
Gary,
As Paul has said "Haunting words"
Keep focused, don't go to far unless you have to, and good luck with it Wink
F4+ Wink
Gary C
« Reply #3 on: February 08, 2010, 11:39:07 PM »
nah,not going in to deep,but I did notice some old rust repairs that need attention. I still dont know what needs to be done with the sump. The 202 is getting a birthday while I muck around with the dodgy conversion.I need it sorted before the sedan comes home (5 weeks) Work is starting to interfere also.
Gary C
« Reply #4 on: February 09, 2010, 04:10:11 PM »
Sound familiar!
 Grin Grin, sounds very familiar, how many of us have uttered those famous last words only to end up doing a full rebuild.
                    Pedro
« Reply #5 on: February 12, 2010, 08:36:07 PM »
And some of us have gone into a full rebuild uttering those words and a few years later..... Huh
Gary C
« Reply #6 on: February 18, 2010, 08:29:25 PM »
OK my outrigger has arrived and it must be eh I think because it does not have holes for the front engine mount. I have it sitting loose on the crossmember and it protrudes the front rubber by about 20mm, do I leave it or are you supposed to trim it back at the crossmember so it sits flush with the end of the outrigger mount? When I removed the crossmember the front 2 retaining caps were missing, three top mounting rubbers were lower fc mounting rubbers with one correct , three different length tube spacers and one tube spacer missing completely. All of the four bolts were finger tight. No wonder there were a few noises in the front end! Any help on the outrigger would be great thanks,
Gary
« Reply #7 on: February 19, 2010, 02:27:56 PM »
I'd leave it long Gary, better too long than too short, I know it wouldn't move 20mm but under heavy braking or the front wheels hitting a pothole the crossmember will have some backwards and forwards movement as it is rubber mounted, sounds like whoever fitted the  previous front end was pretty dodgy Shocked.
      Pedro
Gary C
« Reply #8 on: February 19, 2010, 03:19:05 PM »
Thanks for the reply Pedro. thats all I wanted to hear now I can get on with it.
Gary
Gary C
« Reply #9 on: March 06, 2010, 06:36:57 PM »
The new hump is in and the outrigger and crossmember all sorted.
Found a sway bar,,
Hope it fits
Thanks Gary
GOA350
« Reply #10 on: March 08, 2010, 10:25:25 AM »
Hey Gary, you should pull the front end out of it and cut the outrigger off it, just in case you are wanting to do another HR front end.
Gary C
« Reply #11 on: March 08, 2010, 11:47:24 AM »
Yeah Iam going to grab the crossmember but I was a bit knackered by the time I finished, its the wet season and your sweating your arse off by 6am.
Gary
GOA350
« Reply #12 on: March 08, 2010, 12:44:23 PM »
That makes it no good for doing any painting (humidity blisters)
Gary C
« Reply #13 on: August 14, 2010, 06:34:55 PM »
Well the ute finally got a bit of luv'n the last few weeks
the 202 did one season at the local speedway,we just added a larger solid cam with roller rockers and the su's.
should be a bit of fun.
Gary C
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #14 on: August 14, 2010, 09:11:23 PM »
Lookin good Gary.
How are the other projects going Wink
Regards ACE  Cool
Gary C
« Reply #15 on: August 15, 2010, 02:35:39 PM »
Thanks Ace, the sedan (engine bay refurb) now has door rubbers and trims and just received my new scuff plates so it is pretty much done.
The monaro is going slowly but is looking extremely neat. I got a hk crossmember and are still looking for a repair or replace bathurst
fuel tank.
Gary C
