July 18, 2025, 02:19:09 PM *
Author Topic: steering cloumn  (Read 3354 times)
Fc1958
« on: August 22, 2009, 01:19:58 AM »
anyone want to type out a quick mudmap on how to get one of these outta a fc? only that and the handbrake till i can crack the front end off Smiley
“Old Holdens never die… they just go faster!”
« Reply #1 on: August 22, 2009, 05:47:47 PM »
I think this is everything...
* Disconnect pitman arm
* Disconnect wiring
* Disconnect gear shift linkages
* Remove plates at firewall around steering column
* Unbolt column from subframe
* Remove clamp under column at dashboard end
* Pull steering box end of column into car, remove through back door. If front seat has been removed, this is substantially easier.
Hope that makes sense. Ring me, by the way, if you want to meet up for Eastern Creek.
Fc1958
« Reply #2 on: August 22, 2009, 09:00:28 PM »
Rang @ 1700 but phone off 94840105 if you are still going mate Smiley
« Reply #3 on: August 23, 2009, 04:38:42 PM »
It can be difficult to get the steering box out from around the pedals - I usually find it easier to take the steering box out forward into the engine bay. Drop the honey pot below the pedals and then up behind them. If your pedals are out then you can do it just as easy either way.
Fc1958
« Reply #4 on: August 23, 2009, 09:41:08 PM »
Steering Column out Smiley   tnx for the help.
