July 13, 2025, 08:08:35 AM *
Author Topic: It's raining and my FC leaks!!  (Read 9544 times)
Mutley
« on: June 29, 2009, 09:18:22 AM »
I bought a '58 FC wagon a few months ago (when it was blue skies and warm sun ... great driving weather).  Anyway, now it's raining like all hell and my FC leaks like a sieve.  There's heaps of water coming in the back and all, around the door seals.  I don't think the windscreen or rear window is leaking.  The rubbers appear new (they aren't hard or crumbling) but aren't doing the job.
Is there a way to tell if they have been seated correctly (and don't say 'look for leaks').  Can anyone give me some hints/tricks/tips on replacing the weather seals and also a good place to get the right rubbers?  I'm in WA but don't mind buying interstate.
Thanks for your help.
CraigA
« Reply #1 on: June 29, 2009, 09:50:53 AM »
The wagon tailgates and doors should all seal without issues if the rubbers are newish, un-damaged and fitted correctly.
Check for panel alignment before you do anything though, the rubbers can't seal if the gaps are too wide.
So the approach would be:
1. Check/adjust panel gaps
2. Check rubber condition
3. Replace any suspect rubbers
4. Refit rubbers as per factory
There are some other tricks, like putting Sikaflex behind the rubbers and then lightly closing the doors. This will make the rubbers sit out a bit further and should help them seal better - but its a balance between seal pressure and the door/tailgate shutting correctly.
Contrary to lots of stuff written up here Rare Spares rubbers do fit quite easily and will seal perfectly. So maybe you need to look at a new rubber kit, especially if you are using it daily. They'll rust very quickly if they are filling up with water.  Sad http://www.rarespares.net.au
If you don't have much experience with this stuff then join your local FE FC club, these blokes will always be willing to assist.
Hope some of the above helps.
« Reply #2 on: June 29, 2009, 01:15:11 PM »
surely there is a secret to this?
CraigA
« Reply #3 on: June 29, 2009, 02:01:05 PM »
The horizontal seal that goes between the upper and lower tailgates should be easy to fit and seal without issue. The rares ones even have the correct moulded ends.
The inner seal should be the same.
Did yours leak Ed? If so, where?
« Reply #4 on: June 29, 2009, 09:49:56 PM »
Are you talking about your FE wagon Ed? FE tailgate seals are different to FC and are not as good. If originality is not an issue it is far better to fit FC tailgates to FE wagons for an everyday driver. Not too many FE wagons about anyway I guess Roll Eyes
But I agree with Craig. Old rubbers get compressed and flatten after 50 years so may not seal anymore. Probably better to fit all new seals if you have lots of leaks rather than trying to replace bits here and there.
Johns
Model: something else...
« Reply #5 on: June 30, 2009, 08:48:47 AM »
Bugger Angry
When I finished Nev's refurb, he didn't leak. In my relentless quest for authenticity I had to alter the door seals so he leaked properly. Not only that when we fixed the brakes they weren't randomly locking up, so I fiddled with the lines so that any one would lock up without warning, now much happier opposite locking into Hyundai bumpers, bus queues and the odd shopping centre.
Clearly, if the Rares tailgate seal seals properly, it cannot be authentic and is therefore not original. Next thing you'll be telling me is that the Rares repro sending unit works perfectly, just after I modified mine so that it reads half full until the tank is has a cupful of fuel in it and then swings to empty just as the fuel runs out. Took some effort to get this to work I can tell you.
Soon, I supppose they'll make a hotbox flap that doesn't seize up - more problems.
We are going to have to watch the quality of the stuff these guys are selling.
Signed
Confused but authentic, or is it.....?
NosFEratu
F4+ =^^=
« Reply #6 on: June 30, 2009, 09:43:43 AM »
 Grin Grin Grin Grin  Ah the eternal quest for authenticity!  Grin Grin Grin Grin
NosFEratu
« Reply #7 on: June 30, 2009, 02:18:05 PM »
Lol.
No it had an EK upper and lower.
I think John must have waved the authenticity wand over it.
surferboy
10,000 POINTS !
« Reply #8 on: July 01, 2009, 03:46:17 PM »
G'day Mutley
When you figure out how to stop your 58 wagon from leaking in the rain..
can you come to a club meeting and let me know
Ta
 Cool Cool Cool
come to the meeting anyway
cruisin's great with a 58
cajerridoc
sa-club
WHAT TO DRIVE TODAY?
« Reply #9 on: July 30, 2009, 11:32:03 PM »
Did ED's wagon leak? Yes it does and not just water. Dust too!! The lower tailgate is certainly not the best fitting one I have seen and there appears to be no adjustment left to close the gap. It is like it has a twist in the tailgate. I have not done anything much with it as I don't want to stuff up the paintwork but it will have to be done sometime.
Robin
The sticker says "I'd rather push my Ford than drive a Holden". I agree, I'd rather they pushed their Ford than drive MY Holdens!
« Reply #10 on: July 31, 2009, 12:22:27 PM »
Add more rubber ?
ridgey_didge
act-club
« Reply #11 on: July 31, 2009, 12:34:51 PM »
Too much rain is not a problem that I am facing.  Water restrictions are permanently in place and washing cars at home is prohibitted.  Those high pressure hoses at car washes are not what a 50 plus year old car and its rubbers require.  I have a supply of old towels I use to mop up inside the car and the boot.  Make sure the drainage holes are clear also.
Mutley - send some of your rain east if you can - my garden can do with it.
David
Not Happy Jan
Aussie adventure
« Reply #12 on: July 31, 2009, 06:45:44 PM »
I am also in the process of installing new rubbers all round in an effort to keep the insides dry! The bottom tail gate corners just looks like a perfect catchment point for the spare wheel well!. I have used an aftermarket seal on the top of the tail gate but there is still plenty of room on the outer ends. From my under standing that seal is no longer available??
Question?.... Can an FC wagon be made watertight from rain. Front screen should be ok if done properly. Tell you next week! But rear opening and doors??. From memory my last FC 20 years ago and FC1958's new project was pretty dry.
If it can't keep it dry then  a carpet is just going to be a floor pan demolisher?? Who has carpet and who has vinyl?Huh
You can never have too many!
Port Macquarie NSW
« Reply #13 on: July 31, 2009, 07:13:22 PM »
The most common problem area for front door leakage is between the window and the quarter vent. You should seal the gap where the bailey channel goes into the door. Otherwise the doors will seal no problems.
The tailgate area is another issue and can be difficult to keep dry.
Rusty_T
« Reply #14 on: August 05, 2009, 08:53:09 PM »
 Angry Angry Angry
Mutley
If you have leaks in your wagon ,then try this. My FE Wagon filled up with water on my way back fropm Mt Gambia. This was due to ill fitting panels (Doors , Guards , Tailgates upper and lower and Front air vent.) My spare wheel well was full and the spare almost foating. All the rubbers were new from Rares, but when I picked the car up from where it was painted, not one of the panels were fitted properly. When I returned from the Mt ,the car was opened up for 4 days dry out and then I set about adjusting all the gaps. The tailgate, I had to remove the lower rubber and place it back in the correct position and the upper tailgate on the inside I put another piece of rubber in the same thickness as the original and that sealed it perfectly. It doesn't leak anymore apart from under the guard where it bolts on. Wrong bolts ,and no hole at the top.
Cheers Rusty
