July 18, 2025, 10:02:04 PM *
Author Topic: 202 aussie 4 speed transplant  (Read 4518 times)
GMHwagoon
« on: June 24, 2009, 07:22:23 PM »
gday just after information on a transplant l am doing, Taking out 186 with crashbox 3 spd  and putting in 202 with aussie four speed  now l have been told the centre hump needs cutting out and enlarging also can someone give me information on the best way to hook up the clutch thanks
« Reply #1 on: June 24, 2009, 08:14:47 PM »
In regards to the floor mod, the best way is to fit and EK auto transmision tunnel, alternatively you may be able to purchase a tunnel from CRS or similiar see the following thread to show what has been done by others.
http://fefcholden.org.au/forum/index.php/topic,14706.0.html
In regards to the clutch, you can purchase an aftermarket bracket that allows a FC slave cylinder to bolt up where the pivot linkage would bolt up on the bellhousing. They were made by Dellow, CRS and others. This way the standard hydraulics are retained, I don't know if they are still available but they come up on ebay ever so often, one of the forum members may also have one they want to sell.
GMHwagoon
« Reply #2 on: June 25, 2009, 05:31:28 PM »
thanks for that will investigate into
GMHwagoon
« Reply #3 on: June 29, 2009, 07:16:37 PM »
thanks again picked up bracket from rare spares  and new slave cylinder  took my time and slightly modified it but looks like it will work well
GMHwagoon
« Reply #4 on: June 29, 2009, 07:19:25 PM »
question someone told me the steering column from an ek is shorter than my fc will it bolt straight in and is there any problems that will arise thanks
« Reply #5 on: June 29, 2009, 08:15:04 PM »
EK column will bolt straight in, is about 4" shorter, don't use an auto column on a manual, there is some difference in the indicator setup, from memory you have to use an FC indicator switch, FB is the same steering box ratio as the FC, still the same length as EK,  EK ratio is slightly different. Will all still bolt in.
GMHwagoon
« Reply #6 on: June 30, 2009, 05:24:30 PM »
thanks, for the info , lve got a column from a old ek project has had the honey pot filled in  will wait till l take the other out now to compare both at the same time
