July 18, 2025, 01:32:28 PM *
Author Topic: MOUNTING OF COMMODORE BRAKE BOOSTER  (Read 4802 times)
FATBOY
« on: April 16, 2009, 10:18:45 PM »
Whats the measurement from firewall to back of booster and what size plate do you use for the mounting plate or is there one you can use from a donor car
regards fatboy
ps back on track to finish fc ute
fatboy
0414712441
« Reply #1 on: April 16, 2009, 10:50:16 PM »
Fatboy are you using the VB VH V8 double diaphragm booster  Huh Huh Huh .....FC427......
FATBOY
« Reply #2 on: April 16, 2009, 11:05:48 PM »
open to options ive got a vt and vq stato ones on the shelf but i can get others from the local wrecker
regards fatboy
fatboy
0414712441
« Reply #3 on: April 17, 2009, 07:16:12 PM »
Fatboy I have never fitted VT or VQ if you use the VB VH double diaphragm only one cut on the original VB VH mount to correct the angle and presto it all fits  Cool to the pedal with out any other mods and the original clutch master cylinder still fits if you are using it .....FC427......
FATBOY
« Reply #4 on: April 17, 2009, 08:58:16 PM »
hi mark wont be using a clutch ek ute has worn me out changing gears Ill be running a t 700 box
regards fatboy
fatboy
0414712441
« Reply #5 on: April 17, 2009, 09:23:02 PM »
Hey Fatboy,
When I put the VT booster on the car I have also used the brake pedal and accelerator from the VT. If you are going to do this then the booster mounts straight to the firewall and the pedals mount from the bolts on the booster quite easily.
The booster will also need to be supported to stop fire wall flex. There is provision for a bolt at the front of the booster.
Hope this helps mate,
Jason.
« Reply #6 on: April 17, 2009, 09:34:02 PM »
If you search ''Show us your booster " there are a few photos of different boosters mounted up from a few members cars it might help you to get a visual on what you like .......FC427.......
Page created in 0.046 seconds with 16 queries.
