July 17, 2025, 08:56:10 PM *
Author Topic: paint  (Read 2007 times)
Papa Smurf
« on: December 23, 2006, 12:46:31 PM »
 Have some panels that were painted about 18 mths ago & wondering after 18 mths would I need to start again (primer) or would a good sanding be ok before applying the final coats
fe hotrod
« Reply #1 on: December 28, 2006, 08:09:24 AM »
 :)I would say just a good wash with prep wash would be ok as long as there is no suface rust,which can come through the primer as its porus,maybe a wash with soap and water first then use the prep wash,wax remover next!!.....jamie Smiley
« Reply #2 on: December 28, 2006, 09:40:48 AM »
Is it an etch primer or just a straight primer?
Were the panels done in bare metal or just scuffed up original paint?
If you took the panel to bare metal and it is not painted with etch primer I would take it off and redo with etch primer.  If it has been done with etch primer or over original paint, it should be OK as Jamie has said.
Papa Smurf
« Reply #3 on: December 28, 2006, 01:07:43 PM »
Cheers guys
They have been primered & have 2/3 coats of top coat just to seal the primer
