September 08, 2025, 04:38:33 PM *
Author Topic: New Motor rules  (Read 5863 times)
griffo
« on: August 23, 2006, 07:06:10 AM »
Hi ,
I,m thinking of putting a new motor in my ol girl,
it currently has a 202 red , but getting a bit tired.
If I decide to put a blue or black motor in what do I have to do regarding rego ?? is it just a notification or do they require a engineers cert. Huh  I live in Vic.
Griffo.
« Reply #1 on: August 23, 2006, 09:34:35 AM »
Griffo - depends whether your car already has an engineers cert or not.  If it has a cert, then it is just an engine change form.  Without a cert could be a little more difficult.
fccool59
« Reply #2 on: August 23, 2006, 09:58:31 AM »
not sure about vic but here in nsw you have to run all the pollution control stuff that came with the block so really you should have the air pump, charcoal canister etc, thats the advantage here of a red block
griffo
« Reply #3 on: August 23, 2006, 10:25:27 AM »
Thanks for the thoughts Ken - fccool59
The car has been registered for 12 mths , it didnt require a Eng. cert because it had been registered some time ago with the same motor , so thinking about your replies , I might be better off reco -ing the motor thats already in it , that way I dont have to stuff around with Vic roads.
Anybody had similar experiences ?
Griffo.
FB_MAD
« Reply #4 on: August 23, 2006, 11:34:13 AM »
   If its been registered for the last 12 months with that 202 Red then most likely its been engineer certified for that modification so you should be able to put another red in providing its engine number is from the same model as the certified engine......for example a HQ 202.
But if you fitted a HZ 202 Red then like fccool59 said you would have to also fit all the smog control bits (at least thats how it is in N.S.W ) according to N.S.W RTA.
Then like you said,it might be less stuffing around if you just reco the existing motor and save the potential  headaches that VicRoads might give you if their rules are similar to N.S.W.
Terry.
Has anybody seen my red pen??
Addo
« Reply #5 on: August 23, 2006, 09:10:09 PM »
Have same problem with mine, 202 red on rego papers, no engineer cert available. RTA NSW assures me that if I put ay other motor in the car I will need a Engineers cert. 202 red or not. I'm going to use my block save any hassels.
griffo
« Reply #6 on: August 24, 2006, 06:41:38 AM »
After some more info guys,
Are all trimatic autos the same ?  i.e. will a tri auto from a later mod commodore VH, VK etc , fit up to my old 70's red 202 ?
Griffo,
« Reply #7 on: August 24, 2006, 06:53:46 AM »
I think there's a difference between Trimatic for 6 and V8, but I don't think it matters whether red/blue/black 6.
griffo
« Reply #8 on: August 24, 2006, 07:02:11 AM »
Thanks Ret,
Looks like the best thing to do is
Re build existing motor and fit up new auto while I,m at it ! This will keep the Vicroads people happy and save all the stuffing around,
Any advice gladly taken ,,
Cheers Griffo.
Dr_Terry
« Reply #9 on: August 24, 2006, 10:31:03 PM »
Hi Guys.
RET said:- "I think there's a difference between Trimatic for 6 and V8, but I don't think it matters whether red/blue/black 6. "
The main difference in Tri-Matics over the years is that most early boxes (up to HZ) are RH shift & all Commodores are LH shift.
To convert a Tri-Matic from V8 to 6 cyl (or 4 to 6 for that matter) configuration you can change the bellhousing & front shaft etc. But to convert a box with its shifter on the LH side to the RH side is a lot more difficult.
Dr Terry.
Rob_FE_56
« Reply #10 on: August 25, 2006, 04:10:43 AM »
  G'day Griffo, From what I understand of the vic roads rules for an engine swap you must meet the emissions control standards of whichever was manufactured later.
  Eg.1
hz red 202 into fe/fc would require carbon canister an associated rubbish out of hz.
  Eg.2 Big block chev in commodore would require the engine meets the same standards as the car its going into. Very much a "grey area" (pardon pun).
  Most blokes got around this by running straight lpg but an engineer told me the other day that this is currently under review and will most likely be no longer accepted in the very near future.
  Now ICV type cars such as lotus 7 and cobra's will have to run brand spanking new engines that meet current emissions standards ie quad cam ford v8 etc, making the poor old windsor conversion redundant.
  I think your best bet, as you said would be to freshen your existing engine. It will save a heap of rego headaches and you will probably be happier with the end result anyway.
  Rob.
Page created in 0.039 seconds with 17 queries.
