August 17, 2025, 12:00:03 AM *
Author Topic: A question for Racing red motor guru's  (Read 4655 times)
Addo
« on: August 20, 2006, 05:11:12 AM »
Just poped the lid of my racing 202 red. Nothin flash at first glance. Yellow T roller rockers, YellowT valves in a head originally painted fire engine red. (Big ports!).
The question is the pistons have a small semi-circle cut out or rebate to the front and they have the following stamped on top.
RA9096   060
Bot  .003HB
Any one know what they mean. I imagine its been stroked and everything milled to the max to be pushing the compression it was running.
Haven't dropped the sump yet. Cleanest motor inside I've ever pulled apart.
Thanks for any feed back.
FATBOY
« Reply #1 on: August 21, 2006, 07:33:52 AM »
60 thou over sized pistons the semi circle is a releif cut so that the valve wont hit the piston higher compression
cheers fatboy
fatboy
0414712441
Addo
« Reply #2 on: August 22, 2006, 09:02:18 AM »
Thanks Fatboy but it's not that sort of cut out. It's about 5 mm in diametre and it's located at he front edge of the piston.
They are a flat top piston. Just thought someone might recognise them. It's of to the local engine guy to see what he says and what we can do with them!
« Reply #3 on: August 22, 2006, 09:30:38 AM »
Hey Addo,
From memory the small semi-circle cut out is just a indicator and should face towards  the front of the motor.
Regards ACE  Cool
« Last Edit: August 22, 2006, 09:31:33 AM by ACE » Logged
« Reply #4 on: August 22, 2006, 10:46:58 AM »
as Ace said,
Its a little notch so you put  pistons  in right way,as notch always faces front,they are on most pistons in one form or another all around the world.
Addo
« Reply #5 on: August 23, 2006, 09:14:30 PM »
Well I  must say, that IS a little naive of me!
Thats what happens when you don't play with them for 20 years.
Thanks Guys
Addo
FB_MAD
« Reply #6 on: August 24, 2006, 07:59:52 AM »
Don't be too embarassed Addo.I was a mechanic up to 1989 and I also have to at times ask some plainly simple questions mainly due to lost memory cells in the grey matter Wink
Terry.
Has anybody seen my red pen??
Page created in 0.477 seconds with 16 queries.
