May 19, 2025, 06:17:26 PM *
Author Topic: Somethings Slippin  (Read 2202 times)
griffo
« on: August 13, 2006, 03:14:07 AM »
Hi,
I have a red 202 with a 3 speed auto in my FE, which runs fine ,well almost .
the problem I have is when I accelerate out of a tight corner theres no power, it feels like somethings slippin in the auto, the motor just revs ,  so I back off let the car straighten up and she's fine .
Whats happening and what could get worse ??
Griffo
« Last Edit: August 13, 2006, 06:01:40 AM by stinky » Logged
griffo
« Reply #1 on: August 13, 2006, 03:16:24 AM »
I stuffed up the title should just read " Somethings Slippin "  could someone fix that  Roll Eyes
thanx   Griffo.
« Last Edit: August 13, 2006, 06:02:12 AM by stinky » Logged
« Reply #2 on: August 13, 2006, 06:04:35 AM »
Have you checked the trans fluid lately?
Other than that, I'd be off to a trans specialist.
oldgmh
« Reply #3 on: August 13, 2006, 08:04:30 AM »
sounds like you are low on tranny fluid.   Shocked Shocked
don't forget that you check the level with the engine running.   Roll Eyes Roll Eyes
« Reply #4 on: August 13, 2006, 09:16:20 AM »
and if you do top up, run the shifter through all the gears before checking again.
griffo
« Reply #5 on: August 15, 2006, 06:15:37 AM »
Yep , checked the fluid level and it needed a top up ,
thanks for the help fellas, I think it will also need a trip to a tranny specialist ,
just to check things out.
Griffo.
