June 14, 2025, 01:51:53 AM *
Author Topic: Parts for Sale (SYD)  (Read 1664 times)
« on: August 09, 2006, 08:25:15 PM »
most stuff to suit FE FC FB EK.
Posting on behalf of Andrew Harvey.
Phone 0438670158
Shed cleanout - these bits not needed when the 327 was squeezed into the EK. Most of the spares are ex-EK, though many are shared with FE/FC.
Parts can be picked up from either Greystanes or Rosehill in Sydney (near Parramatta).
Happy to arrange postage for smaller stuff (buyer pays postage), or have courier pick up (buyer to organise courier).
Special take-the-lot deal of $500, and may throw in delivery if your within Sydney area (will discuss).
Parts are available until the 6th of September - anything left gets put into long-term storage. Call 0438670158 (Andrew).
1.      one manual steering column and steering box (honeypot is cracked, all else appears OK) $50.
2.      one pair of HR front disks, stub axles, calipers, backing plates and hoses $70.
3.      one Delco wiper motor and baseplate (no arms or linkages) $30.
4.      one Delco wiper motor (no baseplate, arms or linkages) $20.
5.      one Bosch coil $10.
6.      three headlight wiring joiners (screw onto subframe, used to join headlights back into main harness). $5
7.      one Cuno cigarette lighter (plunger and base) $20.
8.      one Casco cigarette lighter (plunger and base) $20.
9.      two fuse panels (one is cracked). $5
10.     one Bosch regulator $40
11.     one reverse lamp switch $40.
12.     one fuel tank sender unit ($30)
13.     one HR diff, including drums, brake lines, handbrake cable and axles - no centre. $80
14.     two throttle linkages (long bar that runs across firewall, including carby linkage ends). $20
15.     one accelerator pedal and lower shaft assembly. $10
16.     four EK hubcaps (red lion), chrome has some pimples. $15
17.     two gearbox control tubes (1 has elongated shifter hole from wear) $10.
18.     one air cleaner assembly. $5.
19.     two heater cores (about the size of a housebrick), one is a MatraCoolaCore by National Consolidated, other unlabelled. Have not been pressure tested. $20 each.
20.     one rear handbrake cable. $30.
21.     one set of rear axle U-bolts. $5
22.     four front swaybar connection rods (worn - one may be salvageable) and 2 sway-bar bracket/clamps. $5.
23.     one rear brake shoe retaining spring. $5
24.     one set front brake shoes $10.
25.     one front cross-member mounting bracket. $5.
26.     one glass-bowl type fuel pump (later model) $20.
27.     one clutch actuating cylinder (no internals) and hose $5.
28.     one pair engine mounts $5.
29.     one clutch pedal return (over-centre) spring $5.
30.     one exterior sunshade (white) including Coolaride stainless end covers $100.
31.     one taxi-bar, some light chrome rust at ends $50.
32.     four wiring double connectors (2 black, 1 pale blue, one dark blue). Free to good home.
33.     one EK wagon fuel tank, bottom severely dented, filler neck cut off. Top and sides are good (no rust - good donor for patch panels). Free to good home.
34.     one battery earth lead. Free to good home.
35.     one brake cylinder with plastic reservoir and pushrod, seized. Reservoir is useable. Free to good home.
Regards,
Andrew Harvey
slim
« Reply #1 on: August 10, 2006, 01:00:12 AM »
Number 2 , has been sold.
Im located at Liverpool, NSW
« Reply #2 on: August 10, 2006, 03:06:29 AM »
just a reminder guys, contact Andrew directly.
on 0438670158
I just posted on his behalf
