July 20, 2025, 07:08:19 AM *
Author Topic: Installing a diode  (Read 1751 times)
Dave_EH
Keep on Holden' on
« on: July 19, 2006, 04:50:10 AM »
I have just wired a relay to my ignition wire to utilise 12 volts on my electronic dizzy.
I cannot switch the motor off using the key now.
I have been told that the wire from the alternator to gen warning lamp runs enough voltage to hold the relay open and causes this problem.  The remedy is to fit a diode to the genwarning lamp wire.
Could someone please assist me with some more indepth instructions on how to perform this task>
« Reply #1 on: July 19, 2006, 04:59:15 AM »
grab a diode, which only allows current flow in one direction.
solder it in place in the desired position, put heat shrink over the soldered joints.
test out its polarity using a test light or multi meter.
easy?
Page created in 0.045 seconds with 16 queries.
