August 26, 2025, 08:18:20 AM *
Author Topic: Heads  (Read 2256 times)
fcvan
« on: August 13, 2002, 12:21:44 PM »
I was wondering if anyone can help me, I have a 161 red motor and I would like to put an unleaded converted head on it, I can get a 186 head which has already had the conversion but will it bolt straight on.
Effie C
Still Lost & Confused
« Reply #1 on: August 13, 2002, 07:01:02 PM »
G'Day FC Van
A red is a red, it should bolt straight on, with possible slight increase in Compression ratio as the 161 was a low compression motor ,in relation to the 186 that is Wink
Now if it was an almighty, all conquering grey motor it may be different Roll Eyes
John M
The Smoo'er
« Reply #2 on: August 14, 2002, 03:45:52 AM »
Matey,
Before you bolt anything on which will ultimately run on unleaded, I would strongly recommend in getting the exhuast valve seat's hardened, otherwise you'll be coughing up heaps money a few miles down the track
with valves pulled up into the head and paying a bit more.
Hope this helps,  Smiley
Smoo
The Smoo'er
« Reply #3 on: August 14, 2002, 03:52:12 AM »
My stuff up,
I didn't read the word converted in you original sentence . Good luck.
Smoo
Graeme McKie
« Reply #4 on: August 12, 2004, 01:35:02 AM »
149 and 161 engines had closed chamber cylinder heads. They were high compression engines. Look at the back of the head near the heater tap outlet and their should be a L stamped for low compression or H for high compression if you want to make sure. The chamber size is what affects compression ratio.
