September 09, 2025, 01:42:03 AM *
Author Topic: Good Grey Motor & Accessories  (Read 3545 times)
EJ_Dave
« on: June 29, 2006, 05:21:53 AM »
After months of agonizing I've decided to replace my perfectly good grey motor with a red. To help finance the swap I'm offering the motor and some accessories for sale. Details are as following:
J series grey motor $700.
I had this motor professionally rebuilt 5 years ago at a cost of over $2000 . 40 thou oversize pistons and hardened valve seats fitted, 30,000 miles since rebuild. Always fitted with external oil filter, oil changed every 3 months, filter cartridge every 6. Coolant always used in cooling system and recovery system fitted.
**Price is for complete motor with standard rocker cover, exhaust manifold, air cleaner and excluding the external oil filter.
Wade 104 grind cam and refaced lifters $100
Never fitted to motor, standard journal sizes. This is a good street cam offering a good spread of power.
Speco alloy rocker cover $40
AC external oil filter $60
Good hoses etc- replaced 5 years ago
Motovator extractors $80
7 years old, bought new by me
Twin Stromberg manifold and one carby $50
Warnerford brand. Bolts up to standard exhaust manifold if a heated inlet manifold is important to you. Would have to be cleaned up and needs studs fitted. You can have a second (matching) carby if you buy the motor too!
Motor and accesories (except cam and twin stromberg manifold) currently fitted to my daily driver EJ sedan (see pic) so you can come and hear it running or even have a drive.
I'm located in Canberra. Send PM if interested
the_love_god
DARK & STORMY
« Reply #1 on: June 29, 2006, 05:49:38 AM »
Hi Dave , can you give a call on 0418195717 very intro cheers AlfioM
Trevor_B
Melbourne VIC
« Reply #2 on: June 29, 2006, 08:16:11 AM »
Hi Dave,
Please put me down for the Wade 104 grind cam and refaced lifters @ $100 as well as the Speco alloy rocker cover $40 - $140 + postage??
Please PM me bank details etc.
Trevor_B
EJ_Dave
« Reply #3 on: June 29, 2006, 10:58:37 AM »
Alfio,
your number didn't seem to work (too embarrassed to try a third time-the guy sounded surly enough after 2 attempts). Pls check your PM.
slim
« Reply #4 on: June 30, 2006, 08:17:15 PM »
I sent you a Pm regarding buying the Twin carb manifold and Oil filter setup . Cheers SLIM
Im located at Liverpool, NSW
corm
« Reply #5 on: June 30, 2006, 10:53:19 PM »
Hi, Interested i n the extractors and im in belconnen you can ring me on 62580276 or 0407266220 thanks wayne.
EJ_Dave
« Reply #6 on: July 04, 2006, 05:27:24 AM »
De-nuded grey motor still available ($700). All accessories gone.
Still in car so can hear running. Will be removed in 2 weeks.
Page created in 0.05 seconds with 16 queries.
