September 07, 2025, 03:57:44 AM *
Author Topic: rear fin extensions  (Read 6212 times)
« on: June 26, 2006, 10:07:52 AM »
Any one have any rear fin chrome extensions found on models with only a small insert colour?
« Reply #1 on: July 01, 2006, 08:02:51 AM »
any one have a photo?
« Reply #2 on: July 15, 2006, 10:56:08 PM »
still looking (Even in poor condition)
SRVLIVES
« Reply #3 on: July 16, 2006, 01:49:56 AM »
hey nes,
You're after extensions?... or photos? Smiley
I have a pair that I won't now be using, will get some snaps over the next couple days.
« Reply #4 on: July 18, 2006, 05:00:09 AM »
both but prefer to buy them
« Reply #5 on: July 24, 2006, 08:31:44 AM »
just for clarification, what I am after is the piece that runs from the rear boot fins to the rear 1/4 glass (fin extension) So if anyone has any laying about....
« Reply #6 on: July 26, 2006, 04:31:07 AM »
or a photo of one so I can maybe copy the profile and knock up my own...
« Reply #7 on: July 26, 2006, 05:17:59 AM »
Do you mean this bit, from the top of the taillight across the top of the quarter panel?
« Reply #8 on: July 26, 2006, 06:16:24 AM »
not the actual fin itself but the bit that runs on after the top boot fin has finished to the rear 1/4 glass as seen on in the very right upper corner of the photo..
do you have a pair?
« Reply #9 on: July 26, 2006, 07:13:16 AM »
Nes, I have a pair of the extensions you need (I didn't reply earlier because I thought you may get some closer to where you are).  The tag where it is screwed in behind the door rubber is damaged on both of them but the stainless itself is good and straight.  I want $20 for the pair plus freight from Victoria (probably about $5)
Regards   Ken
« Reply #10 on: July 26, 2006, 07:57:43 AM »
Nes, You may also need the correct rear fins to accomodate the fin extensions. The correct fins have a bit machined at the tip and the extensions slide over the top of them  Wink
Regards ACE  Cool
COL58FE
FE225
« Reply #11 on: July 26, 2006, 08:24:33 AM »
G'day,
     These are more commonly found
on 59 model FC'S,might be a thought
when hunting another set down  for
someone else next time. Wink
                                         Col.
« Reply #12 on: July 27, 2006, 12:18:34 AM »
thanks col, ace and mcl for help.....
ace, can the pair I have be cut in a way to accomodate or simply place the extension over the top?
mcl, sent you a pm
« Reply #13 on: July 27, 2006, 01:08:11 AM »
Nes,
I have modified 58 type fins to accept late 59 extensions without any problems. Just measure and use a small file to make the 'adjustments'. It only needs a little taken off.
I have a set of rechromed late 59 fins if you get stuck. Let me know via P.M if you need them and I'll send you a price and picture.
« Reply #14 on: July 27, 2006, 10:08:27 PM »
hey thanks craig
good to know people are looked out for on this forum
now wheres that dam file
« Reply #15 on: August 13, 2006, 04:36:11 AM »
I now have a set.
Page created in 0.046 seconds with 18 queries.
