August 02, 2025, 07:00:25 PM *
Author Topic: Scuff plates??????  (Read 3077 times)
Russ
mmm dohnuts
« on: June 23, 2006, 12:58:23 AM »
the bits of trim that cover the edge of the carpet under the doors (scuff plate?) what holds them on is there a clip or is there ussually a peice of wood in the channel under it to screw to?Huh?
graham_fuller
« Reply #1 on: June 23, 2006, 01:10:11 AM »
Hi Russ,
These screw directly to the top of the sill panel.There should be holes already in the panel where they were screwed originally.
Russ
mmm dohnuts
« Reply #2 on: June 23, 2006, 02:40:01 AM »
I have no holes?HuhHuhHuhHuhHuhHuhHuh??
I'll post a pick to make sure im talking about the right bit
Russ
mmm dohnuts
« Reply #3 on: June 23, 2006, 03:00:35 AM »
I think i may have the wrong plate, apon closer inspection it is different to the other three and does'nt fit that well. here is a photo any way.
« Last Edit: June 23, 2006, 03:45:00 AM by stinky » Logged
graham_fuller
« Reply #4 on: June 23, 2006, 03:17:35 AM »
Thats the plate alright. Have a close inspection of the sill panel.There appears to be  ashadow in the pic which could be a hole.Get something sharp and put it through the kick plate where the holes are when the plate is in position make a mark on the sill panel and see if there is anything like a hole in the vicinity.Is it a sedan?
Johns
Model: something else...
« Reply #5 on: June 23, 2006, 04:21:42 AM »
Russ,
FE/FCs don't have front carpet and only some FEs have it to the rear. FCs have rubber mats there as well. The mats just fit under the inside edge of the scuff plate and the plate screws down over them.
In front the kick panels fit over the mat, helping to hold it in and there is also an evil looking metal clip that holds the mat down on the toe board under the steering column and one in the same position(?) on the passengers side. With carpet you may need addittional fastners over the transmission hump.
Rear should be no problem. The front mat overlaps the rear.
Hope this helps
Russ
mmm dohnuts
« Reply #6 on: June 23, 2006, 04:55:57 AM »
No Carpet? my floors abit to far gone to go carpet free. i've got another FC on the way so i'll check it when it gets here. Ta everyone
« Reply #7 on: June 23, 2006, 06:32:43 AM »
I would say the car has had some filler work on the sills and the holes have been bogged up or the car has had new sills fitted.
The easiest thing to do is sit the scuff plate in position and run a 1/8 drill through the hole.  If there is filler it will go straight through or it will drill a new hole.
Russ
mmm dohnuts
« Reply #8 on: June 24, 2006, 05:45:47 AM »
thanks all Cheesy
