August 27, 2025, 12:03:32 PM *
Author Topic: Gear Box Oil Seal Hint  (Read 1482 times)
Rod
« on: May 28, 2006, 11:35:36 PM »
Because I've got my FC ute out of action(daily driver) I had to do some maintenance on my FE sedan so I had something to run around in.
One job I have put off doing was the gear box oil seal. I have asked the question previously on this forum if two seals back to back could be used for a better seal as other attempts left oil still leaking. I was advised against it.
Anyway I went into the local bearing shop and they didn't have the full length seal only one about half the length. He suggested that I use two seals and it would not cause any trouble. Put the two in a week ago and not one drop of oil has come out the rear end.
I least something has worked in my favor.
Maybe a suggestion if you are having trouble getting that good seal.
Rod
Page created in 0.018 seconds with 16 queries.
