June 09, 2025, 04:49:30 AM *
Author Topic: HR stub axles  (Read 2472 times)
Rob_FE_56
« on: May 26, 2006, 10:57:43 PM »
Hi all, just wondering if someone may have a set of hr disk brake stub axles they may be interested in selling.
Thanks Rob.
COL58FE
FE225
« Reply #1 on: May 27, 2006, 05:42:38 AM »
rob,
     there's a set on ebay at the moment with disc/caliper's and the stub's all cleaned up.they may be of use to you,sorry i didn't get the item number for ya.
just type in (hr stub axle's) and see how you go.
                                                           cheer's col. Wink
Rob_FE_56
« Reply #2 on: May 27, 2006, 06:25:04 AM »
Thanks Col I'll keep an eye on them.
I'm mainly chasing the bare stubs as a mate has come up with a conversion.
Blank p76 disks drilled to fe-hg pattern, trimmed back about 1/4 of an inch on lathe, taper on bearing snout machined flat as per hq-torana mated up with vn calipers.= vented disks on 13 inch wheels and narrows track by about an inch each side so the car can go low with 6 inch rims. I intend to post some photos when I get all of the parts together if anyones interested.
thanks again, Rob.
blacky
« Reply #3 on: May 27, 2006, 10:47:28 PM »
 Rob , best of luck with it , if it works you could be onto a winner there !
« Reply #4 on: May 28, 2006, 09:53:18 AM »
We have tried this on a Torana at work and there was only one difficulty.
P76 rotors start at 25.4 mm thick and have a minimum of 22.74 mm
VN rotors start at 22 mm with a minimum of 20 mm
Hence the VN calipers with new pads wont go over new P76 rotors.  You can take a bit off the pads but you also need to take a little bit of metal out of the caliper cradles for the caliper body to clear the rotor with a couple of mm's each side.
Or you can take a bit of metal off the rotors to bring them down in size a bit.  This shortens the life of the rotors though.
Rob_FE_56
« Reply #5 on: June 20, 2006, 01:55:09 AM »
G' day Ken, a mate of mine has had some success doing this on a torana fairly recently. As you said it took a bit of tweaking of the calipers to make it all fit together. Once we get it sorted I'll post some pics in case others want to follow the same route. Rob.
slim
« Reply #6 on: June 20, 2006, 09:06:15 AM »
Pretty sure Iv got a set. I will let you know tomorrow , Cheers SLIM
Im located at Liverpool, NSW
