August 05, 2025, 05:34:38 AM *
Author Topic: cleaning up olympic air-rides  (Read 1655 times)
coolaride
« on: May 25, 2006, 09:53:18 PM »
hey there
has anyone used a certain product to clean / renew their air-rides ?
would using todays chemicals be to harsh ?
or should i just try good old soapy water ?
or maybe use nothing at all ?
any thoughts ?
thanks
coolaride  Smiley
HAD 708
« Reply #1 on: May 25, 2006, 11:21:55 PM »
I have found that the old favorite Dissol is a great cleaner for tyres it has no silicone in it so no build up etc. I would wash them really well in a hot soapy mix let them dry totally and then wipe them over with a dry cloth.Then apply the dissol liberally all over the tyre and walk away and leave it to soak in  then buff them with a dry cloth again and then repeat as many times as needed you will use quite a bit but it is a good way too clean them back to a original black color rather than the modern shiny look like armorall.
Good luck
Brett
Brett Gillard
coolaride
« Reply #2 on: May 26, 2006, 12:53:52 AM »
thanks Brett
i`ve got a bottle lying around . i give it a go  Wink
Page created in 0.037 seconds with 16 queries.
