August 27, 2025, 03:16:01 PM *
Author Topic: toyota 4sp/4sp into early holden  (Read 2252 times)
Dave_EH
Keep on Holden' on
« on: May 18, 2006, 07:08:22 AM »
For the purposes of conversion to early holden running gear, is the celica 5sp/toyota 4sp the same?
The certainly look similar, and the 4sp housing can be used to house the 5sp for ease of fitment.
More clearly: I have a celica 5 speed and CRS bellhousing. Can I use a conversion kit (tailshaft, slave, bracket, speedo cable, clutch etc) from a toyota 4 speed CRS conversion kit?
nicko
« Reply #1 on: May 18, 2006, 11:45:47 AM »
Hi, im fairly certain you can, i had a v8 with celica 5 speed and blew it up in Darwin,mate had a toyota crown 4 speed and a corona 4 speed both looked the same but i used the crown as it was behind a 6cyl i thought it would be stronger,bolted straight up and lasted fine until i found another 5 speed so pulled it out and put new celica 5 speed back in. all 3 looked very similar and used same dellow bellow housing  and tailshaft,
cheers Nick
Dave_EH
Keep on Holden' on
« Reply #2 on: May 18, 2006, 11:00:30 PM »
Thanks Nicko,
from what I can find out they are basically the same and everything should bolt up.
Page created in 0.019 seconds with 16 queries.
