August 05, 2025, 03:06:54 AM *
Author Topic: internal door cards wanted.  (Read 2340 times)
oldgmh
« on: March 21, 2006, 05:35:42 PM »
Wanted.
Internal door card/trims for a sedan.  Any colour.
thanks.   Grin Grin
« Reply #1 on: March 23, 2006, 06:54:29 AM »
You can buy the door-cards new.  I know this only because I'm currently getting my door-trim vinyl refitted to new backings.  I don't know where they come from, but your trimmer would know where to start asking I would think.
Hope that helps.
« Reply #2 on: March 23, 2006, 11:10:00 AM »
At TAFE we are making door cards out of 3mm MDF, the ones I make at home and the ones from the trimmers are made from Masonite which I think is a bit thicker at around 5mm.
The next set of FE/FC ones I make will be the 3mm MDF as I have run into trouble with the stainless fitting properly and getting the window winders and door handles on.
If you are half handy with a jigsaw, give it a go yourself and save a few bucks. Even if you have to buy a $20 jigsaw from Bunnings you should be able to do a set for less than $40. Spade bits are handy for all the holes too.
blacky
« Reply #3 on: March 24, 2006, 10:37:14 PM »
 I am in the process of making a new set for my car , the trimmer supplied the masonite - it is 2.5 mm thick . Apparently you can only get the 2.5 mm stuff at trimming supplies stores - I tried to get it from a local building supplies wholesaler and it wasnt available.
The trimmer told me that 2.5mm is the right stuff to use for early Holdens because it is the only stuff that the stainless will fit properly - he also said not to use mdf because if it gets wet , it is buggered. Sad
« Reply #4 on: March 24, 2006, 11:23:42 PM »
Masonite and MDF are quite brittle too, so be careful when fitting either. To get around the top stainless not fitting the thicker masonite I bevel the top edge of the boards with a sander.
Bitumen Board is what was used originally, but I don't think it is available anymore.
Interestingly, at TAFE the door trims we made were from older (30's and 40's) cars and their design had their entire back covered with vinyl, purely for weather protection. A modern alternative and good insurance would be to seal the back of the trim with paint/sealer or varnish.
« Reply #5 on: March 25, 2006, 02:18:47 AM »
I used Luan Ply for my door cards, available from timber yards or larger hardware.
It is a thin ply sheet, it has good weaher resistance, I painted mine with marine varnish both sides before re-assembly.
Good luck with yours.
Gary
