August 29, 2025, 12:09:12 PM *
Author Topic: my ute hurry up paint  (Read 5139 times)
« on: March 20, 2006, 05:46:18 AM »
just decided last week to put a but of paint on the old girl to make it feel a bit more loved until i get around to fixing rust in sill panel and front floor.
well actually it is to give myself a hurry up as it does not look so sad sitting on back wall of garage.lol.
« Last Edit: March 20, 2006, 05:47:36 AM by nicko » Logged
« Reply #1 on: March 21, 2006, 10:21:23 PM »
Looking good nicko..
you painted the aerial too??
« Reply #2 on: March 21, 2006, 11:55:43 PM »
the ariel still has masking  tape on it.lol
« Reply #3 on: April 01, 2006, 04:45:21 AM »
didn't like white so repainted it yesterday.heres some pics.
« Last Edit: April 01, 2006, 04:47:01 AM by nicko » Logged
« Reply #4 on: May 10, 2006, 09:53:48 PM »
started welding in patch peices yesterday,20 minute rule blew out to 2 hours ,much grinding required but when i went to lh side behind door i actually heard the sizzle sound instead of crackle and pop that i read about in article i found on mig welding site,means ive finally worked out wire speed myself and smoother welds will come so i can be a bit less scared of doing sill panel myself,lol,sorry i accidently deleted side repair  when cropping photo's,the biggest patch was beside spare wheel  door keyhole then the right side bottom,its funny most have just small area on right and left side bottom must be just the shape traps dirt i suppose,ive seen about 30 FC FE's with rust here and only about 6 had bad rust running past here to corners,the other strange spot ive found that rusts on most  FE and FC's is about 1 inch under tail light's lots of people miss it as metal gets very thin there but often does not break through so is missed in rebuilds luckily i did not find any on this ute but my sedan has it both sides ,had to tap with hammer and sure enough little hole appeared. so beware when looking for needed repair sections.
cheers Nick
« Last Edit: May 10, 2006, 10:06:17 PM by nicko » Logged
COL58FE
FE225
« Reply #5 on: May 11, 2006, 07:28:58 AM »
nicko just a tip,
                       unless it's a super quick/cheap
clean up,you are suppose to fix the rust before
you repaint mate.why didn't you re-move the
chrome bit's first too, alot of work the wrong
way around  buddy,if it's your first
attemp fair enough.but you will not forget ya mistake's,
if you need any tip's just ask on
the forum and someone will help you out with idea's.
beleive me it's easier. Wink
p.s i'am not bagging you,i'am just scratching
my head remembering all my failed attemp's too. Wink
                                         cheer's col.
« Reply #6 on: May 11, 2006, 10:55:55 AM »
i was just making it look good to make me pull my finger out and work on car instead of looking at it in corner of garage looking all too much.
until i put Harko's 20 minute-2hour rule into practice as its getting a full respray when all is done,with all chrome removed.
cheers    Wink
« Reply #7 on: May 20, 2006, 10:16:48 AM »
just the sill on lh side to go now,found the paint reacted to something in couple of spots and welded in patch panels in lower side and back lower sections . not happy with my front guards either little dents (ripples) on both that will need redoing.
« Reply #8 on: June 02, 2006, 06:24:10 AM »
pulled floor out of ute bed today and found only a couple of spots of surface rust, very happy about that,im going to install the drop tank i got from Harko last year soon.
cheers Nick
