August 06, 2025, 05:12:45 PM *
Author Topic: WTB: Cowl drain tube, seat surround panel  (Read 2709 times)
« on: March 17, 2006, 11:57:55 PM »
Hi guys,
I'm after a cowl vent drain tube.. after years of saving mine, I lost it!  don't know how or where but it was fitted to the car.
any idea who makes these?
also, there is a small panel that fits under the lower seat surround at the rear of the seat.  it covers the seat frame from view.
require one (drivers side) or will take a pair if available.
your help is apprecaited
« Reply #1 on: March 18, 2006, 12:14:53 AM »
Is there sonmething special about the cowl vent drain tube? I was just going to get some rubber hose to do mine.
« Reply #2 on: March 18, 2006, 12:17:47 AM »
good question Stinky..
the hole thru firewall is quite narrow, the drain diameter is quite wide.
A thin - walled rubber tube was what I was using.
i'd reckon a heated rubber tube would probably slip over.
that would be too easy wouldn't it?
« Reply #3 on: March 18, 2006, 06:25:26 AM »
I asked the guys at my local Rares today and they said to use the largest bore you can get on there as they tend to get clogged with debris. Nothing special just hose.
« Reply #4 on: March 19, 2006, 10:49:44 AM »
Cowl vent tube is just a piece of hose for a modified car, but a very special hose with a 30 degree bend in it for a restorer
Grin
By the way I have the plastic piece you need for the back of the front seat.  $10
Regards   Ken
« Reply #5 on: March 20, 2006, 10:42:57 PM »
very funny anecdote Ken,
will let you know about the plastic trim cover.
I may go and check out Mike the Beater's stock as it is located between work and home.
leon
My FC Business Sedan
« Reply #6 on: March 21, 2006, 09:04:10 AM »
 :)G Day Ed.
IF you go to Clark rubber  where I go you will find the one your  looking for.
Regards. Leon Wink
« Reply #7 on: March 21, 2006, 08:39:26 PM »
thank you kindly Leon,
Page created in 0.031 seconds with 20 queries.
