August 22, 2025, 04:24:29 PM *
Author Topic: Ute sills  (Read 6427 times)
Ute-opia
« on: July 18, 2002, 12:37:07 AM »
My panel beater has been struggling with my sills which look to have been replaced.  They didn't line up with the rib on the front guard and he's since eye-balled an multi-award winning stock EK ute around Mount Macedon and come to the conclusion that one side was too high and the other side was too high and too far in.  He's taken then off and is in the process of reworking them but he's asked something I can't answer.  He asked about my door seal and I said it was 3 sided, ending at the floor both front and back.  He said the EK was 4 sided and had a chrome strip on the floor.  Does anyone have a photo or an excellent means of describing what's original? Roll Eyes
howie mcquarrie
howie@regcap.com
(m) 040404-44-33
(h) 03-9646-1884
« Reply #1 on: July 18, 2002, 02:50:18 AM »
Howie,
You're panel-beater is right, although the scuff-plate (as they're called) is not originally chromed, but zinc.  The rubber is a one-piece unit.  This picture (hopefully) makes it more clear:
You can buy the rubbers, windlacing and scuff plates from RS if/when you need them.  At this stage they only have FC scuff plates, not FE ones.
PS - Credit where due:  this picture of Kevin Woolard's car was taken by Hewart Wink
Ute-opia
« Reply #2 on: July 18, 2002, 06:24:06 AM »
That is unbelievable!.....what about a rabbit out of a hat next!
Tremendously appreciated.
Cheesy
howie mcquarrie
howie@regcap.com
(m) 040404-44-33
(h) 03-9646-1884
« Reply #3 on: July 18, 2002, 09:26:54 AM »
Howie,  EK front doors have a point at the top of the 1/4 vent window.  This means that the EK door rubber has 4 sides while the FE/FC only has 3 - The front and top being all one piece.
« Reply #4 on: July 19, 2002, 03:39:24 AM »
Ken,
This is not in answer to Howie's question, just time-wasting semantics. Wink
Are we talking about sides as in the perimeter of the door-frame, or as in how many physical pieces of rubber get glued together to make the rubber?
I would have said that an FE/FC rubber had 5 sides, and an FB/EK one had 6, ie:
Code:
FE/FC
FB/EK
Ute-opia
« Reply #5 on: July 19, 2002, 05:10:11 AM »
....man, have I got a long way to go with this learning curve!
I got onto rare spares and ordered my scuff plates and door seals but they sell the wind lacing by the metre.  My car's not terribly handy so can anyone give me a rough idea of how many metres, erring on the high-side?
thanks a mill  Cheesy
howie mcquarrie
howie@regcap.com
(m) 040404-44-33
(h) 03-9646-1884
« Reply #6 on: July 19, 2002, 09:34:31 AM »
RET, I think I'm talking about the number of pieces glued together, but your amazing graphical presentation has made me forget what on earth I was talking about  Tongue
Howie, if you order 2 metres of windlace for each door this will be enough. Actual length requirement is about 1.7 metres.
Ute-opia
« Reply #7 on: July 19, 2002, 09:02:34 PM »
Brilliant......order's in!
Thanks a mill  Grin
howie mcquarrie
howie@regcap.com
(m) 040404-44-33
(h) 03-9646-1884
« Reply #8 on: July 20, 2002, 02:52:38 AM »
...your amazing graphical presentation...
Yeah, who needs PhotoShop when you've got a fixed-width font to make ASCII art with  Grin
Geoffs FE Ute
« Reply #9 on: July 20, 2002, 09:19:49 PM »
How much where the scuff plates from R/S and are they different to the ones on an FE ute compared to FC.I would have thought they would have been the same.Geoff.
Sheriff
FEs rule!
« Reply #10 on: July 21, 2002, 12:01:29 AM »
about the windlacing.  How do you put the windlacing in after the hoodling is in place.  I had my hood lining done years ago and got onto the windlacing later but have not been able to work out how it goes in.  Has anybody got any tips?  Mike
« Reply #11 on: July 21, 2002, 01:43:22 AM »
FE scuff plates are flat on top whereas FC have a ridge running along the length.  Bothe will fit either model though.  Cost is about $85 ea.
Prise the headlining clamp gently away from the body with a putty knif or similar, slip the winlace in, then gently tap the clamp strip back in place with a cloth covered piece of wood.
