May 25, 2025, 06:32:16 PM *
Author Topic: ##URGENT##swapping over a gearbox  (Read 3544 times)
Paul-FcWag
Artist formerly known as Thumper
« on: January 20, 2006, 03:34:36 AM »
Hi all
here I am again at the mercy of the forums infinate wisdom.
I have to put a new gearbox in the fc and dont want to pay $250 to have it done. I have got a secondhand box- big thanks to geoff.
I have tomorrow off work so am going to tackle it myself.
I have an old workshop manual but it is a repro one from supercheap and the details arent too clear to me. it says i have to first drain and remove the radiator and go from there. but im not sure if this is necessary???
its just the gearbox i need 2 swap, the clutch- pressure plate are 12months old.
i have all the tools. i have small ramps to get the car up on and i have a trolley jack to support the engine.
So any and all the advice you could give me would be greatly appreciated. If any1 has a proper manual with set by step instructions that they could scan that would be great and if some1 could translate it into laymens terms that would be even better Grin
I will be logging on at 5am tomorrow morning to get the info and start from then so if you could post any knowlege before then that would be great.
Many thanks in advance.
Paul
TorqueFC
Modified?
« Reply #1 on: January 20, 2006, 03:54:54 AM »
what you will need to do is :
drain the gearbox fluid
remove tailshaft
unbolt the gear linkages
unbolt rear crossmember (where the hand brake cable mounts)
unbolt the slave cylinder
unbolt the flywheel cover
put a jack with a piece of wood across it (easiest way) just to prop the motor up.
undo the rear engine mounts off the plates  (so the box will then only be held up by the trolley jack)slowly let down the motor to the required height to undo bolts & remove gearbox.
then do the same, but in reverse.
somebody else will be able to tell you how much gearbox fluid to put in it
hopefully that helps  :-/
« Last Edit: January 20, 2006, 03:57:18 AM by torquefc » Logged
Royal
« Reply #2 on: January 20, 2006, 07:02:45 AM »
 Hi Paul Grin
 Don't forget to remove the panel in the floor under the mat, makes it much easier and you will have to remove the stater motor as well.  Good luck and just take your time.
                        Roy Grin
Just  "HOLDEN " on
TorqueFC
Modified?
« Reply #3 on: January 20, 2006, 07:45:55 AM »
i knew id forget something . Roll Eyes
also if you cant drop the motor down, because it hits the mounts, and shaking the motor a litle doesnt work, you will then have to unbolt the mounts
greyone
« Reply #4 on: January 20, 2006, 09:20:14 AM »
also a good chance to replace rear welsh plug you jest never know
