April 18, 2025, 10:36:25 AM *
Author Topic: seat belts, ute, bench  (Read 2121 times)
Jonno
« on: January 16, 2006, 07:43:29 AM »
Hi,
Has anyone any experience of fitting inertia reel belts to a ute with bench seat. In particular:
1. if you put the reel on the shelf behind the seat (seems like the easiest option) does the belt cut into your neck?
2. if you manage to weld a suitable mount into the B-pillar (the other option), is there room for the reel at the base of the B-pillar? If not where else can you put the reel?
3. Did anyone (Craig A?) ever find out about the 'Streetwise' system described here?:
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=repro;action=display;num=1082547303;start=
any thoughts (and photos) most appreciated.
Jonno
Cottles Bridge, VIC
utey
« Reply #1 on: January 17, 2006, 03:29:18 AM »
Jonno
I fitted some to an EK ute but I guess it would be similar.
I used Securon belts as the reel unit is very small and fits on the floor beside the seat with just enough room with the seat fully back.
I drilled a hole in the pillar to position the top of the belt
Welded a nut on to a piece of 3mm plate and then pushed the plate into the void between th inner and outer skin, I then bolted the plate in position. Then drilled 4 small holes in the inner skin and spot welded to the plate.
For added strength  I welded a piece  of 1.6mm plate to the inner skin. Maybe should have done some more work to the floor used 3mm plate 50x50 mm
Works great and looks good.
Nick
Jonno
« Reply #2 on: January 17, 2006, 04:21:44 AM »
many thanks Nick,
Did you fix the reel to the floor or the base of the pillar? Don't suppose you have a photo?
Jon
Cottles Bridge, VIC
utey
« Reply #3 on: January 17, 2006, 05:07:41 AM »
fixed reel to the floor.
Can email some pics of finished set up
Dont think I post on this site
Nick
