May 25, 2025, 07:25:57 PM *
Author Topic: Flat Battery  (Read 1641 times)
« on: January 15, 2006, 10:26:56 AM »
Most might already know this trick, but you never know.
I have been using it to test wiring on the black FE and will be doing the same to track the leak causing the FC Wagon's battery to go flat.
When disconnecting/reconnecting the battery earth you will get a little arc when there is something using battery power. eg If you disconnect your battery with the ignition off and you get an arc, this means there is something drawing on the battery.
Martin
« Reply #1 on: January 17, 2006, 06:35:34 AM »
... yep, like the dome light being on cos the door's open.   Wink
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
REDMR2RED
FC Ute's d'best
« Reply #2 on: January 17, 2006, 07:09:23 AM »
If you do it in the dark, it's even easier to see.
Another way is to disconnect the positive terminal and connect a multimeter, set to volts, on the battery terminal and the battery lead.  You will get a reading if something is draining the battery.
Of course this will only work if you don't have an elec clock, security system or other electrical device that remains on drawing power.
Kevin
1959 FC Holden Ute
Page created in 0.036 seconds with 21 queries.
