June 16, 2025, 02:55:31 PM *
Author Topic: parker lights  (Read 4753 times)
Just40
« on: December 27, 2005, 11:55:43 AM »
just asking,are the parker lights meant to go out when you pull the light switch all the way out for the head lights, Tongue
so when the head lights are on you don't get parker lights on,is this right?Huh??
« Reply #1 on: December 27, 2005, 12:00:47 PM »
On an FC this is correct, headlights on, parkers should be off.
Craig
Just40
« Reply #2 on: December 27, 2005, 12:04:48 PM »
thank you,just a bit hard when i didn,t take the car apart.
« Reply #3 on: December 27, 2005, 12:34:57 PM »
Same goes for FE too.  Different location for parking lights, but same basic wiring.
Just40
« Reply #4 on: December 28, 2005, 01:18:02 AM »
now the next question......
the lights for the fuel and oil,gen,temp,they work but the light coming through is very dim,as in cant see it working,but i know the are working...........
« Reply #5 on: December 28, 2005, 02:16:28 AM »
Double check your earth, there's an article in the latest SM about wiring. There's also a quote that most electrical probs are from poor earths.
Martin
« Reply #6 on: December 28, 2005, 01:22:15 PM »
Hey Just 40,
I'm assuming that you're talking about the dash illumination - you didn't mentioned the lighting for the speedo, so this probably works OK.  If this is the case then I'd say the problem is poor contact between the globe holder and the mounting hole in the back of the dash board.  Remove the globe holders form the back of the dashboard and clean all the contact surfaces before replacing them.
The earth trail that Stinky refers to is also important.
(I assume you know that rotating the headlight switch when it is in the "on" position varies the intensity of the dash illumination.  I don't mean to state the obvious, but if you don't know, then it's not obvious!!)
Good luck
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
Just40
« Reply #7 on: December 28, 2005, 09:04:56 PM »
light for the speedo are bright as,so are the light for the fuel and temp,oil,gen       but their seems to be only the smallest amount of light getting through ,in other words the bulbs on but when looking at it from dash side you cant tell it,s on.
even when you cup your hands around it you tell their on.
« Reply #8 on: December 28, 2005, 10:50:03 PM »
Try another globe, sounds like it is the wrong size.
Just40
« Reply #9 on: December 29, 2005, 12:11:02 AM »
wasp nest in both........little buggers
