May 19, 2025, 01:25:49 AM *
Author Topic: alternator/solenoid question  (Read 1791 times)
Jonno
« on: December 04, 2005, 07:30:55 AM »
Hi,
Can anyone (ACE?) give me a pic of the modified bracket required to fit an alternator to a grey motor...there seems to be a protrusion from the block which sits in the way so I assume the bracket has to sit above this?
Also, among this mass of (presumably non-standard) wiring, does anyone recognise what the two boxes in addition to the regulator do? I am intending to pull all this out but am particularly worried by the little box since its connected to the starter solenoid...but doesn't appear in the wiring diagram:
thanks, Jonno
« Last Edit: December 04, 2005, 07:31:39 AM by Jonno » Logged
Cottles Bridge, VIC
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #1 on: December 04, 2005, 08:21:50 AM »
Hi Jonno,
I've emailed you a pic of the alternator bracket, which is a modified red motor bracket.
The 2 extra boxes look like relays of some kind, maybe for driving light, air horns etc.
Regards ACE  Cool
oldgmh
« Reply #2 on: December 04, 2005, 08:27:42 AM »
my guess is that they are relays of some kind.
Driving lights?  Air horns?
Most likely the car probably had voltage drop when starting at some stage in its life, so a relay would have been fitted to give the starter full power.
But that only accounts for one relay which would be the bigger one.
I am not sure about the little box.
Its a start anyway,
Grin Grin
earlee.
« Last Edit: December 04, 2005, 08:30:20 AM by earlee » Logged
Jonno
« Reply #3 on: December 04, 2005, 09:44:36 AM »
thanks guys for photo and advice....I will press on and see how I go.
cheers, Jonno Smiley
Cottles Bridge, VIC
