August 21, 2025, 06:10:05 PM *
Author Topic: Brake booster "type"  (Read 3630 times)
Digger
Classic not Plastic
« on: June 24, 2002, 12:55:27 AM »
Hi Guy's,
Im looking for some advice on fitting a brake power booster to the fire wall, I'm currently running LH disks and callipers with a 1"tandem master cylinder boosted by a VH40 and would like to change it.
What I would like to know is what booster I can use and is there one that will fit and have enough room to mount the clutch master cylinder as well.
Any advice will be appreciated.
Thank's
Steve.
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #1 on: June 24, 2002, 06:47:11 AM »
 ;)HI DIGGER
  I USED A BOOSTER AND TANDEM MASTER FROM A HK HOLDEN.
  IT FITTED LIKE IT WAS MADE FOR THE FC AND NO PROBLEM WITH THE CLUTCH MASTER CYLINDER EITHER.
  HOPE THIS HELPS
  REGARDS ACE  Cool
Digger
Classic not Plastic
« Reply #2 on: June 24, 2002, 07:13:00 AM »
Thanks a heap ACE, Grin
Ace could you tell me if the booster is mounted with 2 or 4 bolts, I was hopeing that the booster might bolt up to the holes I drilled to fit the master cylinder.  Huh
Regards,
Steve.
« Reply #3 on: June 24, 2002, 09:08:04 PM »
Digger,
the booster has two bolts vertically oppposed and a third smaller one just off to the clutch master side.  I welded up the holes on the HK booster and redrilled them to suit the original FC brake master mounts.  The third bolt I drilled a hole for it and welded a nut on the back of the metal plate.
I also made a strengthening arm located up the front of the booster to stop any potential movement whilst driving.
Digger
Classic not Plastic
« Reply #4 on: June 25, 2002, 09:17:44 AM »
ED and ACE,
Thanks a lot for passing on the information it will help me heaps. Grin
Guess what I will be doing this Saturday and Sunday.
Regards,
Steve
Page created in 0.04 seconds with 16 queries.
