September 09, 2025, 12:52:11 AM *
Author Topic: Diff Ratios  (Read 2211 times)
Rod Mathews
« on: April 29, 2000, 12:00:00 PM »
I am looking to possibly changing the diff in my FC Ute. Could anyone give any suggestions on an appropriate ratio which will give good cruising speed, but not to entirely compromise take off speed. Regards
Rod
Richard Thomas (Guest)
« Reply #1 on: April 30, 2000, 12:00:00 PM »
Rod,
What motor?  What gearbox?  Presuming you have stock mechanicals, then the stock 3.89 diff can be swapped for a 3.55 ratio, which will achieve the desired result.  I have seen grey-powered vehicles fitted with 3.36 ratio, but I think going that low puts too much strain on first gear, grey gearboxes not being that strong in the first place.
Hope that helps, Richard
Page created in 0.021 seconds with 14 queries.
