September 07, 2025, 09:45:07 AM *
Author Topic: SPECIAL UNDER DASH A/C UNIT  (Read 18231 times)
heateracman
« on: November 22, 2005, 12:38:37 AM »
UNDER DASH HEATER AND AIR CONDITIONING
OVERALL dimension are as below
NORMALLY $250.00 INC GST
NOW UNTIL NOV 30TH $200.00 INC GST
Dimensions 400 MM X 325 MM X 125MM
COOL K/CAL 2650
HEAT K/CAL 4800
Volts 12
2242EV
The unit has a twin blower wheels with a three speed 12v motor
  Roll Eyes Tongue Grin
UNDER DASH AIR CONDITIONING
TO SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE application
THE UNIT IS NEW
THE CASING IS PLASTIC AND EVAPORATOR CORES INSIDE UNIT
NORMALLY $220.00 INC GST
NOW UNTIL NOV 30TH $180.00 INC GST
Dimensions 380 MM X 280 MM X 160MM
COOL K/CAL 3280
4800
Volts 12
1401ev
THIS UNIT IS COMPLETE WITH UNDER DASH COOL EVAPORATOR
NOTICE: TRADE & WHOLESALER WELCOME Email for price
http://www.geocities.com/radiatorexpert/ OR EMAIL radiatorsexpert@hotmail.com PLEASE NOTE : YOU WILL NEED A/C COMPRESSOR , CONDENSER ,R/DRIER AND A/C HOSES
« Reply #1 on: November 22, 2005, 03:01:39 AM »
Do you have the compressor mounting kit for a "Canadian" grey motor Smiley
ACE  Cool
heateracman
« Reply #2 on: November 22, 2005, 03:48:48 AM »
no
you will have to make you own !!
« Reply #3 on: November 22, 2005, 03:56:00 AM »
In all seriousness, apart from this unit, what else is required to get a car airconditioned?
eg compressor etc, etc and what is recommended to use with the Heater A/C in red motored FE/FC?
heateracman
« Reply #4 on: November 22, 2005, 05:06:06 AM »
the only thing that i can't get but needed a/c hose
The parts that I can get are listed below, all prices include GST.
1. Underdash heat / cool                          $250.00
2. Compressor                                        $320.00
3. Receiver drier                                      $ 18.00
4. Receiver drier bracket                           $ 12.00
5. Heater tap                                           $ 28.00
6. Heater cable                                        $ 28.00
7. Condenser (Parallel flow)                      $165.00
8. Demister vents  x 2                              $ 50.00
9. Round eye ball vents  x 2                     $ 50.00 pair
10. 4 metres of flexible hose                     $ 56.80 4 metres
11. New engine bracket to suit red motor   $177.50
12. Pressure switch high / low cut out       $ 13.50
13. Orings enough for the system             $  8.00
14. Universal condenser mounts/ nuts x 4 $ 14.00 all 4
15. Universal condenser brackets x 4        $  5.00 all 4
16. Universal firewall grommet x 2             $  2.00 pair
               Total price for the above       $ 1,197.80    including GST
oldgmh
« Reply #5 on: November 22, 2005, 07:47:04 AM »
All sounds good but I have a couple of questions :
Where abouts does the new engine/compressor  bracket bolt to?
Is there enough room to fit without modifying the front rail?
Is there a suitable double row crankshaft pulley for the alternator and compressor belts, or do they both run on the one longer V-belt?
thanks.
heateracman
« Reply #6 on: November 23, 2005, 03:23:52 AM »
Comes with Aftermarket crank and water pump pulleys,which bolt on in the kit .  here is a pic of the engine bracket and confirm mounting points, should be ok in an EK as the motor sits high and the comp mounts low under the exhaust manifold on the passenger side.
oldgmh
« Reply #7 on: November 23, 2005, 03:44:48 AM »
Did you actually post a pic?  I cant see it.
heateracman
« Reply #8 on: November 23, 2005, 10:07:28 PM »
i find the picture
oldgmh
« Reply #9 on: November 23, 2005, 10:13:18 PM »
heaterman - you might find the pic because it is already on your computer.  It is not showing to anyone else - cant even see a red X.   Shocked
Can anyone else see the pic? Huh Huh
« Reply #10 on: November 23, 2005, 11:17:31 PM »
Sorry, there's no piccie there to be seen.
Another question, I am at the end (I hope) of my build and funds are tight. Are there replacements to the expensive parts that can be bought from a wreckers? Eg the $172 engine bracket, compressor and condensor?
heateracman
« Reply #11 on: November 24, 2005, 01:00:21 AM »
i find the picture
http://www.geocities.com/radiatorexpert/ek02-1.bmp
heateracman
« Reply #12 on: November 24, 2005, 01:03:04 AM »
the problem is that yes you can buy stuff from the wreckers ,but the systems could be stuff internally
« Reply #13 on: November 24, 2005, 01:20:37 PM »
surely the wreckers will have pulley's hoses,and brackets plus compresser a lot cheaper and in good condition
as when we ad your under dash unit we are heading very close to $2000 just for air con in our cars.,
heateracman
« Reply #14 on: November 24, 2005, 10:01:34 PM »
if you included some one to make up the a/c hoses and gas (r134a ) the systems up ,this can be achieve for less the $1500.00 if you install the rest of the gear which is listed above .
any other question ,feel free to ask
i have completed this task on a couple of times
graham_fuller
« Reply #15 on: November 24, 2005, 10:07:07 PM »
Where are you located? And do you have any pics of your units installed in old Holdens?
heateracman
« Reply #16 on: November 24, 2005, 10:19:30 PM »
WE ARE IN BRISBANE
AND I WILL GET PICTURES AND POST THEM
graham_fuller
« Reply #17 on: November 24, 2005, 10:21:45 PM »
the_love_god
DARK & STORMY
« Reply #18 on: November 25, 2005, 12:40:01 PM »
Hi my name is Alfio from n.s.w l have a FE sedan with VK fuel injection black 202 with auto.l am inters in your system.would you please help me to what l need to fit in type of set up l have in my FE.my num is 0418195715 or email me on alfiom@optusnet.com.au ASAP starting to fit up the wiring soon thank you regards Alfio
« Reply #19 on: November 25, 2005, 11:01:50 PM »
Hello,
Have you got brackets to suit Holden V8 (308). also can you show pics of the mount position.  Preferably a high mount.
Can a condensor be mounted under a car floor at a slight angle using it's own dedicated thermo fan?
Page created in 0.051 seconds with 18 queries.
