August 04, 2025, 10:58:34 PM *
Author Topic: fe nasco options  (Read 4360 times)
COL58FE
FE225
« on: October 12, 2005, 11:03:39 AM »
good fe special on ebay at the moment here is the
link:http://cgi.ebay.com.au/Original-1956-Holden-FE-Special-Sedan_W0QQitemZ4580140292QQcategoryZ1258QQrdZ1QQcmdZViewItem
« Reply #1 on: October 12, 2005, 11:48:39 PM »
The Nasco options aren't anything particularly special, but it's an unusual colour combination.  I don't believe it's a '56 FE though, just the same.
Still, nice to see another FE turn up in WA.  They seem very thin on the ground over there compared to FCs.
SpeciFEcation
« Reply #2 on: October 13, 2005, 12:37:31 AM »
It's the same colour as mine - built May '57. I've e-mailed the seller and confirmed this with the information on the ID plate (from the WA one).
Spec
« Last Edit: October 13, 2005, 12:38:07 AM by speciFEcation » Logged
COL58FE
FE225
« Reply #3 on: October 16, 2005, 08:48:11 AM »
well well,
             just over $5,000 starting bid .
bummer no sale. :-/.
                               cheer's col. Wink
KENNY56
« Reply #4 on: November 01, 2005, 12:04:11 PM »
Hi , so what is the body color called and /or id number.   Thanks    Ken.
FRED THE FIESTY FE
SpeciFEcation
« Reply #5 on: November 01, 2005, 10:55:34 PM »
The trim codes are as follows:
Trim: 234-474 (Granite Grey over Sky Grey)
Paint: 253-7693 - Sky Grey (Duco), 1956
         253-7700 - Granite Grey
The interior trim is grey and white (on the seats).
« Last Edit: November 01, 2005, 10:56:17 PM by speciFEcation » Logged
COL58FE
FE225
« Reply #6 on: November 01, 2005, 11:44:50 PM »
ret,
     ive been scratching my head to why you think this is not a 56 fe.as looking at mine the only thing i can see different is mine has a colour coded steering colum, is this the difference   Huh.
                                    cheer's col
« Reply #7 on: November 02, 2005, 01:52:27 AM »
Col,
The original sales brochures show colour-coded columns for all sedan models (even standard and business), but the wagon and ute/van brochure show them as black.  I'm not exactly sure when the colour-coded steering column was deleted, but it is certainly a feature of 1956 FEs, as is different trim on the rear window.  1956 FE-225s have trim that look like this:
Later FEs have the thicker, wider trim also seen on FCs.  This was changed at around SA body #20,000, which would be roughly Jan/Feb 1957.  Someone else (ie Ken) might know exactly when the changeover occurred.
COL58FE
FE225
« Reply #8 on: November 02, 2005, 06:23:49 AM »
Ret,
     it appear's my 56 may have had a rear window change then at sometime as it's the thick type trim.that's a bit of knowledge for me as i didn't know about the thin trim,anyway.
                                           cheer's Col.
« Reply #9 on: November 02, 2005, 07:21:44 AM »
I also asked for the ID plate details.   The body number is 20084 A which places it around late March / early April '57.
The parts book indicates the rear window mould changed at the following body numbers
20620 A,   1672 M,  11234 S
This means the change occured just after this time.
Basically there were reported field problems of rear windows falling out and the thicker trim was introduced as a fix.  I think the problem really stemmed from the inherant weakness of the 1956 FE rear body structure.  The later "body fixes" introduced in late April 1957 seem proof of this.
