July 27, 2025, 06:23:23 AM *
Author Topic: Fuel Sender Gasket  (Read 1961 times)
griffo
« on: October 05, 2005, 07:37:16 AM »
Just removed the fuel sender for a clean up and it needs a new gasket
the fixing screws also need new seals ,
Can onyone tell me what type of material I should use and where do you get it ?
Griffo.
« Reply #1 on: October 05, 2005, 10:05:48 AM »
I just made a new gasket for mine out of some petrol resistant thin rubber sheet. It's probably 2-3mm thick, made a template from what was left of the old one.
You should be able to pick up an offcut from Clark Rubber for next to nothing, unless someone else has a better idea.
FCwagon
« Reply #2 on: October 05, 2005, 07:39:00 PM »
Hi Griffo,
Rare Spares sell the gaskets but the screw seals I doubt you'll get anywhere. The original screws are alloy with a soft centre and are designed to complete the electrical circuit. I used small fibre washers with a small metal washer on top and all operates well.
cheers,
Leigh
Red & white is alright
griffo
« Reply #3 on: October 07, 2005, 09:51:18 AM »
Thanks Stinky, called in at clark rubber today and got me some of that rubber ( $ 2.50 ) cut out a gasket and wacko! all fixed . Liegh dont have a Rares handy so I gave the rubber idea a try thanks for the input
Griffo.
Page created in 0.03 seconds with 21 queries.
